Old 12-06-2006, 07:27 PM   #1
boot85
71 Chevy
G87 Powerloc diff
This is the rear end code for the truck I bought last week. Are they any good? I saw a post today and somebody said that the G80 diffs were basically garbage, is this one in the same family? Also it does not have a ratio listed does any one have a quess as to what it may be? I have not driven it yet so I am clueless as to what RPM's it turns. It is on a 3/4 ton so my guess would be 4:10 or 4:56.
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 12-06-2006, 11:14 PM   #2
skchevota
skchevota's Avatar
Re: G87 Powerloc diff
G87 is a dana 60 with a powerlock... Very nice.
It should be either 3.54 or 4.10 gears
skchevota is offline   Reply With Quote
Old 12-06-2006, 11:29 PM   #3
72dually
72dually's Avatar
Just to clarify...........G80 is a code for posi, and aren't all necessarly junk. Lets just say the gov locks aren't the preffered unit. G80 code has been used for years, some units are very strong, some are indeed garbage
70 GMC shortbed fleetside with a 72 chevy costume
72dually is offline   Reply With Quote
Old 12-07-2006, 01:12 AM   #4
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
well, crap. I have a G80 positrac in a parts truck, is there a definite way to tell if it's junk or not? It's a 4.11 ratio BTW...
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 12-07-2006, 08:08 AM   #5
Blazer1970
Blazer1970's Avatar
If it is from the '67 - '72 era, a G80 is a normal Eaton limited slip (posi). Sometime in the mid '70s GM switched to the Eaton automatic locker ("gov-lock") while still using the G80 RPO code. The gov-lock is the one that people don't like.
Blazer1970 is offline   Reply With Quote
Old 12-07-2006, 08:19 AM   #6
boot85
71 Chevy
The one on the truck is original so it must be the '67 - '72 era normal Eaton limited slip (posi). I am assuming that it must be a Dana since it is not an HO52.
71 C10
72 C20
62 Chevy II 2DR HT
Old 12-07-2006, 04:53 PM   #7
Blazer1970
Blazer1970's Avatar
Yours, with a Dana 60 and the G87 option is a Dana Powerlock which is also a limited slip. The Eaton limited slip was used in the corporate axles (12 bolt and in later years the 10 bolt).
Old 12-07-2006, 05:20 PM   #8
72dually
72dually's Avatar
Yeppers, and both units are very reliable
