Old 12-07-2006, 04:41 PM   #1
pat
pat's Avatar
Rear drum brake problems
After putting my truck back together and getting the e-brake cable setup and tight, the back brakes dont work well. I adjusted the cable where it is pretty tight and when I push the ebrake all the way down it pulls hard, but it doesnt make the rear wheels lock up, I can still force them to turn by hand.
I put new pads on the rear drums, installed everything correctly (I think) and as far as I know I have the pads adjusted out as far as I can get them. During the short time I putted the truck around, the rear brakes wouldnt grab.
Any ideas?
Im still using the original drums, Im thinking maybe they are worn down too far, might try to take a couple pictures tomorrow.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 12-07-2006, 04:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Rear drum brake problems
Sounds like they need adjusted up a little more.
Old 12-07-2006, 06:13 PM   #3
cdowns
cdowns's Avatar
adjust them all the way out till you hear and feel them contacting the drums then adjust them a couple of clicks in
