12-06-2006, 02:09 PM | #1 |
Drop Spindles?
Anybody know where I can get some drop spindles for a '72 3/4 ton C-20.
12-06-2006, 02:31 PM | #2 |
Questionable
Re: Drop Spindles?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-06-2006, 03:09 PM | #3 | |
Re: Drop Spindles?
Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
12-06-2006, 03:25 PM | #4 |
Re: Drop Spindles?
Just looked at Early Classic's Drop Kits. The only spindles I found were 2'' drops that convert C-20's 8 lug to a C-10's 5 or 6 lug rotor. I have to keep it 8 lug because of the Dana 60 dually rear axle. Thanks for the help so far.
12-06-2006, 05:27 PM | #5 |
Questionable
Re: Drop Spindles?
Good luck! Hope you find something. I've never seen anything except 5-lug and 6-lug. If CPP (classic performance), McGaughy's and ECE don't have it, I dunno who else will. Check with GMCPauls.com and Classicheartbeat.com - either might be able to help.
12-06-2006, 05:55 PM | #6 |
Re: Drop Spindles?
I have been on the search also and the only option I found was Aim industries and they are for the 73 Up 8 lug but that is as simple as a ball jiont switch. I do however have questioned the quality of them. They have a disclaimer saying offset wheels may break the spindle and I feel if a 3/4 ton spindle breaks due to offset wheels It shoouldn't be sold, But thats my opinion. I chose to Z the frame to get the drop instead and run stock spindles for now
12-06-2006, 06:24 PM | #7 |
Re: Drop Spindles?
I've heard the same thing about AIM as well about broken spindles. What do you mean about "Z"ing the frame, that's a new one for me.
12-06-2006, 06:34 PM | #8 | |
Fabricate till you "puke"
Re: Drop Spindles?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-06-2006, 06:49 PM | #9 |
Re: Drop Spindles?
Check out this project, his ride has a 3" Z in the front(pics not quite half way down the page). You don't have to go that low if you don't want, I think he also has a body drop.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
12-06-2006, 06:50 PM | #10 |
Active Member
Re: Drop Spindles?
If I was you I would stay away from AIM I have been to there factory and used some of there products it is junk!
12-06-2006, 09:11 PM | #11 |
Re: Drop Spindles?
Here is a thread with some links for Zing a frame
http://67-72chevytrucks.com/vboard/s...ighlight=frame Also, do a search, there is ALOT of info in the archives here, if there is anything I can help with just PM me |
12-06-2006, 09:43 PM | #12 |
Re: Drop Spindles?
I just installed the AIM spindles on 72 c20. They fit ok and went to oreillys (sp) asked for c20 upper and lower balljoints. Three hours later had 3in drop up front w/spindles and 5 out back w/ springs. Have no rubbing or bottoming out issues. Even installed the block hugger headers from flowtech w/minor mods at the muffler shop to make it fit. I tell you what you will like the look it gives the truck and ride is very nice compared to stock. Put in some thrusher cherry bombs w/ turndowns and sounds mean. Will post pics tomorrow and maybe a vid.
12-06-2006, 09:55 PM | #13 |
Re: Drop Spindles?
Pics would be great. What is your opinion on the quality? Did they seem to fit well? I can't wait to tuck some of the lugs on mine , after all I got 8 on each wheel
12-07-2006, 12:53 AM | #14 |
Re: Drop Spindles?
Quality was good did not have any issues installing. The guy that did them said it was like installing spindles on the other blazers and trucks that he has done. The guy that I had installed was shopped around because wanted to use someone who knows what they are doing. I believe he said that it took longer to put the springs out back because bolts holding the spring were siezed (sp) and had to be replaced. Will try to have pics up soon. I have oem steel white 16.5 wheels and will stay 8 lug. Cost is just as much to convert to 5 or 6 and cost to get 8 lug wheel. Why convert if we already have disc up front.
12-07-2006, 11:47 AM | #15 |
Re: Drop Spindles?
Well Zing the frame is alittle bit more than I am wanting to get involved with. I found some 2 1/2 drop spindles listed at Classic Perform for 71-87 C-20's and of course it says call for price but I guess they have them so I'm going the easy route. Thank you all for your input.
12-07-2006, 04:31 PM | #16 |
Re: Drop Spindles?
Here is a link for a 2.5" drop from performance online that is 8 lug.
http://www.performanceonline.com/sto...at=1076&page=1 Includes brake rotors, drop spindles, bearings, calipers, etc. Check it out if you don't want to z the frame. Also they offer a deluxe kit with a power booster and m/c. http://www.performanceonline.com/sto...at=1074&page=1
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 Last edited by st1x10; 12-07-2006 at 04:32 PM. |
12-07-2006, 09:07 PM | #17 |
Re: Drop Spindles?
