Raising a 2wd C/10
Hello guys I am starting to fix up my Dad's old truck. It is a '72 C/10 long bed 2wd. What is different about it is it has a 4 cyl turbo diesel from a tractor in it, which is heavier than a BB. I am planning to use the truck to pull my gooseneck trailer to antique tractor pulls.
Right now my plan for the rear is to put a Dana 60 axle in the rear under the trailing arms with the stock coil spring and also a air bag overload. The front is where I have the problem. I saw these springs http://www.airbagit-store.com/produc...sp%3Fid%3D2205 but wanted to know if anyone had ever used them. I am just wanting to raise the truck about 2 inches and have the load capacity to pull the 7000 lbs gooseneck. Any suggestions or comments are welcome. Thanks Andyt
'72 Custom Deluxe C-10 Allis Chamlers 4 cyl. Turbo Diesel engine, Ford granny low 4 spd. trans. '91 Dodge D250 Cummins Diesel Antique Pulling Tractors: 1956 Allis WD45 Diesel 1960 Allis D17 Diesel 196? Allis D21 Diesel |
#2 | |
Re: Raising a 2wd C/10
Sparknotes.. Avoid them at all costs. |
Hey leftcoast66 Thanks for the warning. Does anybody else sell these and will my ideas work? Thanks for the help.
Andyt
Shouldn't be too hard to do. I would look for rancho or a company like that for the front springs. If it's not on their site, I'd just call, odds are they can get a pair of front springs w/ 2 inch lift on them pretty easily, and I would just tell them if they ask for motor it's a BB because of the weight
you could also just use stock BB springs with a 3/4" coils spring spacer...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
I found that Rancho makes a 1.5" taller coil spring (#RS6500). This spring is listed for the C-10 and C-20 trucks, Blazers and Subs. I called Rancho, the guy could not tell me if they would work for a BB or not. But he did tell me the spring rate for it, 1050 lbs. I thought this seemed like an awful low number.
Does anyone know what the stock spring rate is for 1/2T and 3/4T? I got to get this nailed down before Christmas so the wife knows which one to get me. Thanks AndyT
![]() Join Date: Aug 2003
fabtech suspension sells a 3" lift coil for small and big block trucks 73-87 #ftsc104. i am sure they will work since i had coil springs from a 74 in my 69 longbed when i had it.
