Old 12-11-2006, 07:02 PM   #1
corn
How to fix this hole?
I could have swore that I posted this yesterday but its not here anywhere.
Someone at some time punched a nice hole in my AC box. Can I unbolt the broken half & just replace it or should I make an aluminum plate or something to cover it? I think something bolted to it that is actually functional would be the best but I cant think of anything to put there. Any ideas?
corn is offline   Reply With Quote
Old 12-11-2006, 07:17 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: How to fix this hole?
Anything flat ( steel, tin, plastic) will work. You could also lay some fiberglass mat over it. It is where the vacuum reservoir bolts to the case. You can also unbolt that half of the case and replace it.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-11-2006, 08:06 PM   #3
Billla
Billla's Avatar
I'd glass it
Billla is offline   Reply With Quote
Old 12-11-2006, 08:54 PM   #4
cdowns
cdowns's Avatar
i'd do a glass patch also// i believe there was a round vaccume resoiver ball that mounted there to maintain enough vaccume to run the ac/heat controls
Old 12-11-2006, 08:55 PM   #5
Andy4639
Old member
Andy4639's Avatar
If you look in the left coner of the picture you can see the vacuum canister on the side of the box.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-11-2006, 09:51 PM   #6
corn
If I remove the bolts from that side I can just pop it off? Sounds easy...
Old 12-11-2006, 10:56 PM   #7
roj2323
this might be a good oppertunity to dress up the AC box with a plate of stainless or aluminum. make it look as good at that BBC you have.
just a thought.
ondrew
roj2323 is offline   Reply With Quote
Old 12-11-2006, 11:07 PM   #8
corn
I think an aluminum plate would be cool if I had a remote HEI coil on it or something like that. The plate would be a lot easier in the long run. Heck, if I know. I do know Im sick of looking at that hole thats for sure...
Old 12-12-2006, 02:12 PM   #9
Americanrider
Pic of a 67 AC unit, hope it helps.
Americanrider is offline   Reply With Quote
Old 12-12-2006, 04:51 PM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Vac canister was there.You could plate it or if you glass it over(borrowed pic)
sneakysnake is offline   Reply With Quote
Old 12-12-2006, 05:05 PM   #11
shifty
Questionable
shifty's Avatar
Black Duct tape. Sorry, but, not a show truck, and that's what duct tape is made for!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-12-2006, 05:26 PM   #12
wolfthing2000
It distracts from your engine............................So throw it away!!!!!!!!!!!!!
Just kiddin.
wolfthing2000 is offline   Reply With Quote
Old 12-12-2006, 09:12 PM   #13
corn
Sorry, but it doesnt have to be a show truck to still want it to look nice. Clean, straight drivers get my attention way more than any show truck ever will...
Old 12-13-2006, 01:56 AM   #14
shifty
Questionable
shifty's Avatar
I've seen duct tape jobs look clean as hell. And, that's what it's for! (ducts)
What do you think will look better? A blob of fiberglass on the side, or a nice, straight-lined duct tape job across the side? You could even do the whole box.
I know what I would pick
Old 12-13-2006, 11:25 AM   #15
ridge runner
Rip the A/C junk out and roll the windows down.
ridge runner is offline   Reply With Quote
Old 12-13-2006, 12:55 PM   #16
wolfthing2000
What he said!!!
Old 12-13-2006, 01:30 PM   #17
centsless
centsless's Avatar
Yes. If you unbolt that half of the case, it can be removed. It will have some sealer holding it on also, but most of the time it is so dry, the case will just come right off.
2003 Suburban
1981 Corvette
Old 12-13-2006, 01:36 PM   #18
Jim_PA
Duct tape will look like sh*t within a year or so. I would either replace that half, or take it off, put a plate over the inside, and glass over the outside to make it look half decent.
Jim_PA is offline   Reply With Quote
Old 12-13-2006, 02:27 PM   #19
shifty
Questionable
shifty's Avatar
Cut it out to a circle, get some 12ga steel that is .5" larger around the sides, Cut the steel into a square, pre-drill it, silicone around the circle and pre-drilled holes, then rivet the plate in and spraypaint it or put an inoccuous looking sticker on the panel so it looks stock.
Old 12-13-2006, 02:37 PM   #20
el curioso
el curioso's Avatar
go under cover with the sticker.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-13-2006, 02:48 PM   #21
Shane
Shane's Avatar
Take the box loose ... split it ... add your fiberglass matte on the BACK side ... let cure ... add just a smidge of bondo to the front to fill ... sand smooth ... reassemble halves ... spray entire box in semi-gloss black.
Good as new.
Shane is offline   Reply With Quote
Old 12-13-2006, 03:01 PM   #22
skchevota
skchevota's Avatar
good reason to buy an MSD box and cover that hole!
skchevota is offline   Reply With Quote
Old 12-13-2006, 04:31 PM   #23
lofly'a
lofly'a's Avatar
i'd go with the previous answer of glass if you want the hole to disappear. take that half off, duct tape the outside, and lay a layer of fiberglass on the inside. let it set up a couple hours, then take the tape off the outside and put a layer of glass on the outside. sand, and paint with a semi-gloss black and no one will ever know it was busted. the easy route is to take a patch of metal and paint it black and glue or epoxy it on. don't use duct tape unless you like replacing it every few months or so (engine heat), and your condenser will suck in dirt every time the tape falls off and gum it up in no time.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-14-2006, 01:13 AM   #24
70clone
70clone's Avatar
clear duct tape , youll never know its there lol!!!!!!!!!!!!!!!!!
70clone is offline   Reply With Quote
Old 12-14-2006, 03:36 AM   #25
longhorn72
Like somone earlyer mentioned you can put aplate on the inside and fill glass the outside. If you glass the plate onto the inside you wont have to drill unsitely holes for mounting screws. You can also add color to the glass ressin to darken it up to match as close as possible anyway. And yes you can pull just the one half but you might ruin the gasket on the back if your not careful as they like to stick. Good luck
longhorn72 is offline   Reply With Quote
