Old 12-10-2006, 10:10 PM   #1
BCOWANWHEELS
9" Ford Or Rear End Question
Hey Guys I,am Wanting To Install A 9" Ford Rear End In My 1971 Chevy Truck. What Is The Best Doner Vehicle To Get A 9" From. I, Got A Set Of 2.47 Ratio Gears For It Which I Need For Doing My Cummins 4 Bt Swap To Keep The Rpm,s Down. Diesels Turn Half Of A Gas Engine In Rpm,s.
Bob
BCOWANWHEELS is offline   Reply With Quote
Old 12-10-2006, 10:36 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: 9" Ford Or Rear End Question
I used one from a 1975 lincoln Continental. I think 67-78 have rear disc, and they generally are 3.00 gears.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-11-2006, 12:07 AM   #3
69TowRig
You want one that has the 31-spline shafts for sure. If you get one with Torino-style housing ends you can swap Explorer 8.8 discs onto it. Most of the late 70s 1/2s have 3.50s in them.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-11-2006, 01:06 AM   #4
BarryB
BarryB's Avatar
with john on this one. plus they are already 5 on 5 lug pattern. Not sure about the width.
BarryB is offline   Reply With Quote
Old 12-11-2006, 02:52 AM   #5
BCOWANWHEELS
I Want One Out Of A Ford Truck, Its A More H/d Housing. And I Agree 31 Splines For Sure. Guess I,ll Send It To Moser And Have It Cut To Width If Its Too Wide But Surely A Ford Truck And A Chevy Truck Are Real Close To The Same Width. Moser Can Drill The Bolt Pattern On 5x5 Too. Rear Drum Brakes Are Fine For My Application. Thanks For The Imput Guys. The More Minds The Better.
Bob
Old 12-11-2006, 02:20 PM   #6
John Fabris
TOTY 2006
Most of the ford 9s from the lincolns are sitting behind a ford 460 big block.....
Also, these rear ends are the same width as the 71-72 chevy truck rear ends, and they are 31 splined, 5 on 5 lug.
John Fabris
67 C10 SWB
Old 12-11-2006, 02:29 PM   #7
72dually
72dually's Avatar
Bob
A heavier duty housing.......You must be joking right?
Its your choice, but why would you invest money in shortening a housing, when for less money you could have the lincoln with disc brakes?
70 GMC shortbed fleetside with a 72 chevy costume
72dually is offline   Reply With Quote
Old 12-11-2006, 03:19 PM   #8
BigSky71
LAIDOUT
BigSky71's Avatar
I have installed a 9" from a '66 Bronco. Its the small end bearing version, hopefully it will hold up under mild abuse. I choose that rear-end mostly for its width of 58.75", which will allow me to tuck 20x10s with only 3" of backspacing. For me, big lips are the bomb !
I didn't look for a Lincoln 9" but my understanding is that you will be really fortunate to find one at all...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 12-11-2006, 03:56 PM   #9
bretcopsey
I think I have to agree with the comment about the 'heavier duty housing' comment. But you also gotta consider what the intentions are. Is he wanting to pull something out of a donor and slap it under his truck, or have whatever he finds professionally built?
Around here the Versailles and Mark IV are getting more and more difficult to find. Also, if I'm not mistaken most came with 29 splines.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 12-11-2006, 06:19 PM   #10
72dually
72dually's Avatar
Around here the Versailles and Mark IV are getting more and more difficult to find. Also, if I'm not mistaken most came with 29 splines.[/QUOTE]
Yes 28 spline.......I guess I kinda take for granted how easy these lincoln rears are to find. As far as the versailles goes, even the junk yard owners are pulling them before the cars hit the yard anymore. I understand why, you can sell them all day long for $500+ to the 67-9 camaro guy's
I'm sorry if that came off rude, that wasn't my intention.
Old 12-11-2006, 08:07 PM   #11
novajess1972
novajess1972's Avatar
Isn't the term "mild abuse" kind of an oxymoron??? Like abuse can be mild. Sorry, just goofing around again.
J
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 12-11-2006, 08:11 PM   #12
Slammed70
Slammed70's Avatar
You see Banks 4x turbo cummins.....that thing raps 11,000 RPM, Its insane.
The 1600HP/3500TQ isnt bad either.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-12-2006, 02:19 AM   #13
BCOWANWHEELS
AROUND here lincoln rears go for big bucks. i,am gonna go the truck 9" h/d route and have moser do the machine work and probably go the 385.00 for a set of 31 spline new axles. thanks guys for all the imput. the more minds the better.
bob
