Old 12-11-2006, 11:18 PM   #1
SCOTI
SCOTI's Avatar
67~68 Buckets: Original or Modify?
I have a set of original buddy buckets for my 68 that are in so-so shape w/some surface rust on the console 'compartment'. The seats will most likely require new foam but are mostly intact.
My dilemma is I want to permanently mount my air-ride stuff while keeping it inconspicuous & I'm considering modifying the console to accomplish the task.
My idea is to mount the 'switches' in/on the front of the console compartment (under the front lip of the seat foam). I would like to be able to reach down to the front of the console/seat & make height adjustments, but keep everything hidden otherwise. I still have to figure where to mount the gauges & want to keep them inconspicuous as well (mounting them in the 4-lower holes of the factory gauge cluster would work if I could match all the gauges..... anything besides hanging them in plain view under the dash line).
It's not like the console compartment is some ultra-rare, unobtainable item.... it's a sheetmetal box that could be duplicated if necessary (or the area that is modified for the switches could be replaced just like you would do when filling in a side-marker light).
What do you think?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-11-2006, 11:37 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 67~68 Buckets: Original or Modify?
sounds like a good idea to me, the box is same as the one used by dodge so a spare isn't too difficult to get, should you decide to go back original.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-12-2006, 02:23 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
I was thinking the same thing, only use a hinge style ashtray for the mechanism to have it all swing out when you want it and be hidden when you don't. Hides everything- see crummy pic: Circles are gauges, squares are switches...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-12-2006, 09:19 AM   #4
SCOTI
SCOTI's Avatar
The ART style gauges I have are pretty deep (not sure they would allow the pivot vs. the depth of the compartment).
I originally was thinking of just putting them in the console compartment facing the headliner but thought mounting the switches withing reach on the front wall of the compartment & having the gauges in sight would be better.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2007, 09:07 PM   #5
Hart_Rod
Hart_Rod's Avatar
What do you think?
Scotti,
Are you still considering this modification? If so I got a box that someone has already modified and am looking for an original box. If you are still planning on doing this, wanna trade ?
Hart_Rod is online now   Reply With Quote
Old 02-11-2007, 09:59 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Your gonna want the gauges where you can see them when rolling. Beyond that I say cut it up. It's only metal...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-11-2007, 11:40 PM   #7
SCOTI
SCOTI's Avatar
Originally Posted by Hart_Rod View Post
.... If you are still planning on doing this, wanna trade ?
Forward some pics of your modified box if you can. If the area that I would be modifying is the same, I'm sure we could work something out.
I'm currently playing w/an idea of using an overhead console like those in the 99-03 Chevy trucks for the gauges. I want to mount them in the factory cluster. The problem is it gets expensive real fast when you're trying to match the fonts of all the gauges.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2007, 05:46 AM   #8
Hart_Rod
Hart_Rod's Avatar
Here are some pics. The front of the box was cut to put in the wooden cup holder.
