Old 12-12-2006, 03:17 PM   #1
BrentRS1985
BrentRS1985's Avatar
Turn signal broke
whats the name of the little plastic piece inside the steering column that the turn signal lever screws into, my turn signals still work, but don't turn them selves off anymore, and I'm tired of drive 10 miles before I realize they're still on.
edit: oh by the way, I have a tilt column if that matters.
BrentRS1985 is offline   Reply With Quote
Old 12-12-2006, 03:24 PM   #2
kyull67
kyull67's Avatar
Re: Turn signal broke
I'm pretty sure it is called a turn signal cam.
Try this site.
http://www.manestruckparts.com/store...&Category_ID=8
kyull67 is offline   Reply With Quote
Old 12-12-2006, 04:09 PM   #3
BrentRS1985
Try this site.
yeah, I'm pretty sure thats it, thanks!
1969 C-10 Short Bed
Old 12-12-2006, 05:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the part that the turn signal lever screws to is the switch it's self.
The cam is the round plastic piece that slides over the shaft and isn't bolted onto anything.
Old 12-12-2006, 06:23 PM   #5
68SHORTBOX
68SHORTBOX's Avatar
It's called a trun signal switch cam, the part that slides over the shaft is called the cancel cam , parts are available to repair or just replace the entire switch. Try this link pages 48-49 for parts.
www.truckandcarshop.com
68SHORTBOX is offline   Reply With Quote
Old 12-12-2006, 06:31 PM   #6
chevyboy55
chevyboy55's Avatar
If it's just a matter of turn signals not canceling, you most likley need a turn signal canceling spring.The hardest part is removing the wheel.You can get the springs at either the chevy dealer or local parts store.If you pull your wheel you will likley find a broken spring.that's what mine was.
http://www.truckandcarshop.com/trucks60_72/t60_049.html
chevyboy55 is offline   Reply With Quote
