What's the easiest way to replace this grommet?
'69 Step
Re: Steering column grommet ?
pull the column
I made a long cut on the bottom of the grommet and slipped it on. Cut it all the way through. It's a real pita to remove the column just to put that on.
1997 GMC Sierra Ext 1965 Mustang |
Questionable
Mine already had a slit in it when I got it, and it made my life a lot easier.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
mine also has the slit in it.alot easier to remove that way.
