Brake problems
My brakes aren't working too good. I think i have a problem in the lines, because the master cylinder isn't leaking from what i can tell. What should i do to fix them? Should i take it in or is this something that's easy enough to do myself.
Re: Brake problems
easyest truck out there to do brakes on.. if you have drum brakes start by replacing all the wheel cyls..if you have disc brakes.. replace the rear wheel cyl's...
remember 80% of pedal height is rear brakes.. 80% of braking power is the front brakes... replace the rears even if they don't look like there leaking. for disc brakes.. replace all 4 on drum brakes even if they don't look like there leaking.. always replace them in sets... |
