Old 12-14-2006, 03:36 AM   #1
longhorn72
Re: How to fix this hole?
Like somone earlyer mentioned you can put aplate on the inside and fill glass the outside. If you glass the plate onto the inside you wont have to drill unsitely holes for mounting screws. You can also add color to the glass ressin to darken it up to match as close as possible anyway. And yes you can pull just the one half but you might ruin the gasket on the back if your not careful as they like to stick. Good luck
longhorn72 is offline   Reply With Quote
Old 12-14-2006, 11:35 AM   #2
Roland
Junior Member
Roland's Avatar
If your A/C works; if your heater core doesn't leak, I'd steer clear of removing the case half. You will probably have to remove the entire unit in order to get this side off but if you are able to remove the one side, you will ruin the seal and have to take the other side off to replace it anyway. If you are going to add a vacuum canister, it could be used to cover any repair you make to the hole and if you only want to stop up the hole why not go to an electrical supply house (or maybe even Home Depot) and get a conduit plug which is used to plug unused holes in electrical boxes. Another alternative would be a plug used by plumbers to stop up unused holes in a kitchen sink. If you are insistent on removing the side, I think I have an extra one that has no breaks. I will have to look. If you need it let me know.
Roland is offline   Reply With Quote
