12-13-2006, 12:54 AM | #1 |
Bolt in air bag
Does anyone make one for a 72? Also I'm going to be towing a 5000lb load alot. Will the air bags hold up? What kind should I get? Thanks.
12-13-2006, 01:10 AM | #2 |
A guy with a truck
Re: Bolt in air bag
Yep. For a '72 they're basically bolt-in. You do have to drill a few holes.
Check this thread for pictures. The bags will hold as long as you get some that are rated for that kind of weight. Remember, the original application of these things is for big-rigs...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-13-2006, 11:04 PM | #3 |
Re: Bolt in air bag
The piston style bags ECE sells bolt into the stock spring bolt holes. You just need to open the upper hole up just a touch.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
12-14-2006, 02:15 PM | #4 |
Re: Bolt in air bag
hear is a link you can go to to get the info on pressure and weight rating for some of the air bags http://www.macsspring.com/website/sl...ties-frame.htm
http://www.cardomain.com/ride/2461088 |
12-14-2006, 08:06 PM | #5 |
Outlandish Trends - FL
Re: Bolt in air bag
With all due respect....ECE's system is wayyy overpriced. I understand they are not in the air-ride business, but their airbag setup is really not something I'd recommend.
-Bret 67 short-fleet sold! |
12-14-2006, 10:23 PM | #6 |
Re: Bolt in air bag
I understand, I was just letting him know they do bolt in with very little hassle. They will sell the bags individually from the kit. They're still $200 apiece which is pricey (like everything else they sell), but the do ride VERY nice.
12-15-2006, 11:13 AM | #7 |
Re: Bolt in air bag
Thanks for the input guys.
