It followed me home?
Is this the correct badge/emblem?
I need to buy some fender emblems and I want to make sure that I have the right ones before I order them. Will this badge line up with these holes? Thanks for any help
Adam
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Active Member
![]() Join Date: Oct 2002
Re: Is this the correct badge/emblem?
The C/10 emblem is from 1969-70 it should fit in the top two holes, the bottom two holes are for the engine size call out emblem.
The 292,350 or 396 |
anybody have a close up pic of the badges mounted on the truck?
Insert Title Here
mine doesnt have the emblem anymore, but you can see where it was.. the holes are 7 inches apart on that one... I need new fenders, so I just stuck these on for the hell of it, so I didnt bother cleaning it up
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Heres the only pic I have & its for a CST-10 but you get the idea...
Active Member
My 68 has a bowtie with a 10 under it. Don't know what year you are working with.
Jack |
thanks cornfed, that helps
This is supposed to be a '70 but I am just not sure. I want to make sure that the holes in the fender match the badges I order. Are the holes in the fender different each year?
Insert Title Here
I measured it for you already.. if your holes are 7 inches apart then that C/10 badge will fit
#9 | |
great, thanks
