Engine displacement
hi all....
how would i know the engine displacement on a chevy pickup k30 whether it is 305 (5000 cc) or 350 (5700 cc). i know the engine is V8 is there a tag or is it writing some where ? Last edited by Shamil; 12-19-2006 at 03:42 PM. |
Re: Engine displacement
welcome to our addiction. The VIN will tell you what engine it has as long as the engine is stock otherwise there are numbers on the block that will indicate. More experienced guys will chime in and give you more exact info....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
yeller
As Jon said, look at your options tag inside the glove box.
There is also a number stamped on the block, directly in front of the pass side cylinder head. If you can locate it, go to mortec.com, there you will be able to decode it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
