Old 12-19-2006, 10:29 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
73-87 Axle fit 67-72???
Bought a 4x4 for $100.00 Today, It is missing The axle's & transfer Will the newer axle's & Steering box mount to this frame????, Also what year is this from the doghouse, Title said 68 & i know that is wrong.
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 12-19-2006, 10:36 PM   #2
arkracing
Weekend Warrior
Re: 73-87 Axle fit 67-72???
Nose is '69-'70
I think the front axle from the newer trucks will fit - there rears need the spring perches moved *I think* I'm not positive - hopefully someone else will know for sure
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-19-2006, 10:42 PM   #3
Americanrider
Yes on the swap, D44's will bolt right in. I have a 75 axle under my 67 and a 72 steering box. Before the swap I placed the 72 and a 76 PS steering box side by side, there was no difference. From the grill it looks like a 69. Take the vin number and go to GMC pauls' website, he is a vendor here. Maybe you can de-code the build date. Here is the link:
http://www.gmcpauls.com/vin_model_engine_axle_info.htm
Americanrider is offline   Reply With Quote
Old 12-19-2006, 10:43 PM   #4
1969k10stepside
Clip appears to be off a 69.The axle should work but keep in mind these trucks came stock with lockouts and a newer axle might not but if it doesnt have a transfer case you dont have to worry much about that because you can just use the one that was in the truck the front axle came from.It can be a 68 title but actually a 69 model year too.Nice score,where are all the 4x4s hid in Indiana?I could only find one
1969k10stepside is offline   Reply With Quote
Old 12-19-2006, 11:10 PM   #5
msgross
msgross's Avatar
nice find...I am getting ready to put a 75 Dana 44 under my 68 K-10. looks like everything will fit and I only paid $125 on Ebay. Complete (rotors, lockouts, 3.07 gears, steering stabilizers, etc..) except for the calipers. I will have a 68 closed knuckle Dana 44 if you are wanting to go back to original for your 69. I will be travelling back to Indy in the spring too...
msgross is offline   Reply With Quote
Old 12-19-2006, 11:12 PM   #6
Olden Days
Living In The Past
Olden Days's Avatar
Originally Posted by arkracing View Post
Nose is '69-'70
This is correct. I just put 1976 axles on my 72. I had to cut off and reweld the rear spring perches inboard. front axle went right in.
Olden Days is offline   Reply With Quote
Old 12-19-2006, 11:26 PM   #7
MJN
MJN's Avatar
yes, rear axle spring perches will have to be rewelded. The older '67-'72 frames, or at least the springs were skinnier than the '73 and newer. I ran into this when I put and Eaton rear in my '79 Suburban and had to widen them.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 12-20-2006, 12:00 AM   #8
earl87gta
earl87gta's Avatar
the fronts will bolt right in you will need a rear from a 1ton or you will have to move the spring mounts. Im going to do the same thing on mine so I can have disk breaks. That is if I can find a 3/4 ton front around here some ware.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-21-2006, 10:39 PM   #9
Troy-Built
As far as 4x4's go I just bought my 8th one last week. I now have a 1 67 1/2 ton, 1 68 3/4 ton, 1 69 3/4 ton, 1 70 GMC 3/4 ton, 1 71 1/2 ton 2 72 K5's, 1 71 3/4 ton 4 of which run and drive nice. Needless to say, I am trying to corner the market on them in Indiana
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 12-21-2006, 10:44 PM   #10
1969k10stepside
Guess you didnt get them all because I just got my newest one.A $350 SWB K10 out of a junkyard.BTW,you have a PM.
Old 12-22-2006, 01:18 AM   #11
EFI70Blazer
Active Member
EFI70Blazer's Avatar
I am pretty sure one of the shock mounts has to be changed also. My 86 the shocks are staggerd and on my Blazer they are both on the same side of the axle. I you end up putting in a 14 bolt rear, get one from a 1 ton, they bolt in without having to change the perches.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 12-22-2006, 04:26 AM   #12
toomanytoyz
Luv the Crewcabs
Thanks for all the info, I have a mid 70's Blazer parts Truck with Axles, Tanny, Transfercase that will end up in here as time permits. This is a back burner project for now.
Want to concentrate on My 67 Stepside & the 72 Wrecker 1st, I found another 68 Doghouse at the Junkyard today. Im very partial to the 67-68 Front's so all mine will have this look.
Here are a few more Pics of this one as it was found, As u can see it's gonna need some work to get back on the Road........
Thanks, Rick
Old 12-22-2006, 11:39 AM   #13
1969k10stepside
It looks like you are missing some frame on the front of the red 4x4
Old 12-22-2006, 11:07 PM   #14
toomanytoyz
Luv the Crewcabs
Good Catch, I checked out some more of the pics i have since Truck is not here yet & It was cut off on both sides. I called the Guy up & ?? him as to what had happened & he said his son had cut off this huge hideous homemade bumper to put on another truck & never got around to it........
He reminded me that he had pointed out the bumper laying close to Truck & asked me if i wanted it since it had been on that Truck, I Didn't pay much attention to it as it was so Ugly............
Again that was a good catch on that as i hadn't noticed it originally, Guess i will wait till i get it home to decide if i truly want to rebuild this now, Scheduled to go pick up the Wrecker on Thursday & will go pick 4x4 after that.............
Thanks, Rick
Btw, Where are u located in Indiana???
Old 12-22-2006, 11:12 PM   #15
1969k10stepside
I am located near Vincennes in Knox county.Welding on new frame horns are easy.I need to do the same on my 69 K10.I cut the front of the frame off a 69 C/10 to use.Usually there is a set of them on here or ebay for sale around $20.If you need pics of what they should look like stock I will get you a pic.
I would keep the 4x4 whether you need it now or not, there is not many in Indiana and I keep any I find in the yard till I am ready to rebuild them.
Old 12-22-2006, 11:31 PM   #16
toomanytoyz
Luv the Crewcabs
Thanks for setting my mind at ease on that, I thought it might be beyond Hope, ................
Scheduled The Wrecker Pickup for next Thursday, I ordered a Operator & Parts Manual for the 480 holmes Bed off ebay, Got it in the mail Today & will be my Bedtime reading.
Thanks Again for All your help & Advise, Thats why i love this Board.........
Rick
Old 12-22-2006, 11:32 PM   #17
1969k10stepside
Good luck on getting it home,hope there is no trouble
Old 12-23-2006, 12:47 AM   #18
7387chevys
as clean as that truck is I would weld some new frame horns on
Sahne
7387chevys is offline   Reply With Quote
