#51 |
![]() Join Date: Mar 2006
Re: Lt1 Engine Harness & Swap
I bought an LT1 harness off of a board member who had it reworked by Speartech and it looks pretty good. I bought a different harness at a recent swap meet just because it had an extra few feet to the PCM connections but if that wasnt the case I would use the Speartech in a heartbeat. I guess I will put it in storage in case I do another swap.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#52 |
Here are a few pics of the harness i got 2nd hand from Speartech. Note the code reader plug and check engine light.
#53 |
Ok help me out guys. I am to the point where I need to remove the wiring harness from the donor Caprice I have and I need to know if I can just cut it on the interior side of the firewall or does this junction come apart?
#54 |
![]() Join Date: Sep 2000
you will have to cut a bigger hole and pull it all through.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#55 |
i got a street & performancein mena ar harness super nice cost me some buck 750.00 they have some nice stuff
#56 | |
If I were doing a gm swap I would certainly call Howell fuel injecion, very reasonable on price and superb on service, even years later with upgrades etc. You won't be sorry. PS he builds indy car harnesses and was the electrical engineer at chevrolet |
#57 |
![]() Join Date: Apr 2005
68 Chebby
"superb on service, even years later with upgrades etc" What updgrades did you do later?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#58 |
#59 |
Like this:
#60 |
New Member
![]() Join Date: Jun 2006
I used a Street & Perf. harness on a 96' LT4 I put in a 40' Ford Tudor. Harness was perfect, no VATS or EGR. They no longer rebuild OEM harness. Used a 96 Vette/Iroc ECM, they programed the chip for that as well. I tried a company in San Antonio, bout half of the sensor connectors were wrong, sent it back and called S&P in Mena, Ark.
Don't forget the steam line on the throttle body, the bung in the radiator has to be higher than the back of the head. Learned that one the hard way, on a brand new aluminum radiator. Another good mod on install, is go with after market distributor, OEM had problems with condensation even though they ran a vaccum line thru the distributor. |
#61 |
New Member
Another Pic
