Carrier Bearing ?'s
Hi guys, I'm new to the board. I just bought a 1970 1/2 ton with the 350 and auto transmission. My carrier bearing is gone and I need to replace it soon. How hard of a job is that? Any tips or tricks? Looks like I can unbolt the drive shaft from the differential and just pull the second half of the drive shaft from the spline? It's a two piece shaft.
Thanks, Scott |
![]() Join Date: Sep 2005
Re: Carrier Bearing ?'s
okay ti not that hard it is easier if you remove the whole drive shaft from the truck.
first start but removeing driveshaft . 2.(mark drive shaft realtion (to put driveshaft back together the same way) 3 remove center u joint 4.remove yoke 5( you might need a press for this step) remove old carrier bearing 6 install new bearing 7 reinstall yoke 8 reinstall new u joints (note it might be best at this time to replace all u joints) (also besure to align marks on driveshaft 9 reinstall drive shaft being sure to tighten th 2 carrier bearing bolts and the 4 rear u joint bolts. 10. go for a test drive
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 12-18-2006 at 10:40 PM. |
Wow, that sounds like a job for an auto shop. I don't have a press. Guess I'll see what they're charging these days.
Thanks, Scott |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
![]() I have done my share of u-joints by hand and have since learned to let a shop press the old ones out and the new ones in. You can do the carrier bearing yourself.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
i've gotten mine so down pat that i can remove and install new rubber+houseing on my bearing since the housing breaks about every 3 months that i can pull the drive shaft and install new parts in about 30 mins
last time mine broke it only took me about 30 min. when i got my new one i welded some braces on the sides because i don't trust the small spot welds.
I have done this a bunch of times without a press. My last one took about 40
minutes, I was lucky that the bearing came off the shaft without a fight. I always soak everything down with P.B Blaster, then use a tie rod seperator ( pickle fork) to tap the old bearing off. Avoid the cheap Autozone 20$ carrier bearings , they tend to fall apart every 6 months. I bought a cheapie last time because I didnt want to wait 3 days for a NAPA one. I have had to reweld it back together twice because of poor spot welds. The NAPA one runs around 50$.
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
![]() Join Date: Feb 2004
IMHO you guys are right, those stinkin carrier bearings and the u-joints go out quite often.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
DODGE SMACKDOWN CLUB
I have found, even though its more money it will save you money in the long run to just have one either lengthened or made to fit. Turn your two into one solid unit
im glad i dont have to deal with them lol
well no driveshaft shop around here will make one long enough for my long bed most wont make one over 64 inches long
In the 6 years ive had my panel ive gone through 2 carrier bearings. Last time one went out I replaced all the ujoints I just used a bench vise, you need one socket small enough to push on the bearing cap and one bigger than the cap put one on each side and then tighten the vise down it presses the cap out, when you put the new ones in just use 2 sockets small enough to fit on the caps and your set. Next time I think i might just spend the cash on one of the inland empire carrier bearings.
here is the inland site.i want to get one of these too but mine hasen't broke again yet so i will wait.
http://www.iedls.com/bearings.html |
Let me start by saying
![]() Last edited by theznuts; 12-21-2006 at 02:32 AM. |
#15 |
i have never seen one like that. what year is your truck
#16 |
#17 |
Opps, sorry. I forgot the info, I have a '70 GMC 1/2 ton with a 350.
#18 |
#19 |
![]() Scott |
#20 |
to remove drive shaft remove the 4 bolts on the rear yoke and slip forward then slide drive shaft back and pull out of trans
#21 |
Designated A-hole!
I've done it before and it wasn't too hard (I have average or better mechanical ability and a limited toolbox). BTW Welcome to the board to the new guys.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
