turbo enthusiast
removing wheel locks
I bought a truck and the PO had lost the wheel lock key. Whats the best way or removing them if the vehicle is not running or driveable?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
Active Member
Re: removing wheel locks
what type of wheel locks are they? is it the kind with the smooth outside that has some type of lock that goed inside the top of the nut, or is it the kind that have the ridges on the outsid eof the nut that the key slides over?
turbo enthusiast
"the kind with the smooth outside that has some type of lock that goed inside the top of the nut" thats the type
Born Psycho
![]() Join Date: Feb 2001
i have special sockets at work made by snap-on made especially for that purpose. sometimes you can use a cheap 12 point deep socket and drive it on with a bfh.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Active Member
weld on a old lug nut might work, havent tried it but i would think it might be the easiest
sufficiently talented fool
![]() Join Date: Jun 2006
If I remember, a 22mm 12pt socket will drive over the lock enough to remove it.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
![]() Join Date: Feb 2004
Gotta love those BFH's
Other than that contact the local tire companies, they might have the snap on tools that you need that they just might let you borrow or remove for a small fee. I love the BFH anyways, If you strip those lugs on the way out, they are nothing to replace. Good Luck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
its all about the +6 inches
i did mine with the BFH and a 12 point, hell, I put them back on and ran them with no keys for 5 years
I have done this twice,,,
the first time I used a 3/4 deep socket and a bfh. trashed the socket the second time I used a 3/4 deep impact socket and a bfh. mushroomed the drive end of the socket but nothing that wasn't fixed with a dremmel.
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Sears has craftman socket set that is made just to remove the lugs works good. But a deep 12 pts socket should also help even better with air tools.
![]() Join Date: Mar 2003
I have taken my die grinder with a cut-off wheel and cut a slot in it. Then hit with a chisel
