12-24-2006, 12:24 AM | #1 |
step side rear tire size rim width
Can the step side people help out here? I'm wondering what size tire I can fit in the rear of my truck. I pulled off my bed today because I found the right bed for my truck (came with a 66 step side, didn't know the truck well enough to know when I bought it, but now I've got a 68 bed). Anyway, there seems to be quite a bit of room in there with the bed off.
How wide a tire can I run with a stock short bed? I'm also now thinking of shortening the rear axle a couple of inches, converting to a 5 lug and "mini tub" the bed. Nothing pro street or anything, just widening the wheel well a couple of inches. Is there a shorter axle that I can swap in there or should I just narrow what I have? Truck 12 bolt, (not sure if I should waste the money on this rear end or not or if there is a more cost effective way?) Last edited by whatnow123; 12-24-2006 at 12:25 AM. |
12-24-2006, 01:01 PM | #2 |
Re: step side rear tire size rim width
The 71-72 five lug rearends are a little bit narrower than the six lug ones. About 2 inches or so. Kill 2 birds at the same time - convert to 5 lug and get a narrower axle at the same time.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
12-24-2006, 02:01 PM | #3 |
I am running 17x8 w/ 4.5 bs and a 275/55/17 tire. I have about 1 1/2" clearance to the bedside
12-24-2006, 02:33 PM | #4 |
I thought this was the opposite? The earlier rear ends were narrower than the 5 lugs?
12-24-2006, 03:24 PM | #5 |
the 69 and earlier 6 lugs are about 1 and 1/2 " narrower. The newer 5 lug axles will permit you to run a bit more backspacing and still not rub.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-24-2006 at 03:25 PM. |
12-24-2006, 08:55 PM | #6 |
My bad. I hope I didn't cause any problems. I always thought the newer were narrower.
12-24-2006, 09:31 PM | #7 |
No biggie Bob. Merry Christmas, let's talk trucks!!!
12-24-2006, 09:56 PM | #8 |
According to an e-mail from XXL when I asked about his wheels, he said that he used a 17x8 with 5" backspacing all the way around wearing 255/50-17's. He also noted that on the back he used a 5/16" spacer, and that the 5/16" was critical. Keep in mind that this is with airbags that allow the tire to fully tuck into the stepside fender. Also I believe that he is using an axle from a 71 or 72, which is wider than the earlier years. Maybe he will chime in here and confirm what I've said.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-27-2006, 11:08 PM | #9 |
Active Member
I have the same question, I have a 70 and it has the 6 lug rear end. Found some 18x8.5 with 5.5 inch of back spacing and was'nt sure they would fit or look alright and have not gotten a chance to measure yet.
'70 Chevy stepside, ECE discs & 4/6, '00 GMC ext. cab stepside, never ending project '07 GMC Crew Cab, 24's & 5/7 "We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing" |
12-28-2006, 01:31 AM | #10 |
71 rustless in texas
Not a step side but I'm running the stock rally 15" X 10" with P295/60/15 on them and I got about 1 1/2" on the outside and 2" inside.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
12-28-2006, 01:50 PM | #11 |
Here is my truck with 275/60/15's on an 8" rim with 4.25" bs. The older pic is with 275/60/17's on 17x9.5 rims with 5.5" bs. The 17's rubbed on the inside of the bed with the deep backspacing. A smaller tire or 5" bs would've fixed the problem.
