Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 12-29-2006, 11:20 AM   #1
engrdean
Starting Truck After 15 Years
I am going to attempt to start my truck after it has been sitting for 15 years. It was running when it was last parked but it hasn't been touched since then. I am putting in new points, plugs, and battery. New gas and oil of course. At this point I am just wanting to hear the motor run, not drive it. What else do I need to be concerned about?
engrdean is offline
Old 12-29-2006, 11:24 AM   #2
Mt Man Chad
Mt Man Chad's Avatar
Re: Starting Truck After 15 Years
My biggest concern would be frozen/rusted piston rings.
Spray a little oil in all the spark plug holes. spray all the way around the piston if you can and let it sit for at least a day or two.
Cheers
Chad
Mt Man Chad is offline
Old 12-29-2006, 11:35 AM   #3
krue
Designated A-hole!
krue's Avatar
Pour some Marvel Mystery Oil down each spark plug hole and let it sit a day. Then rotate it by hand to make sure it's free rotating, then put the plugs back in it and fire it up.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is online now
Old 12-29-2006, 11:36 AM   #4
engrdean
Thanks Chad, I will definately do so. The motor only has about 50,000 original miles on it so I would rather not destroy it the first time I try and crank it over.
engrdean is offline
Old 12-29-2006, 11:45 AM   #5
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
It wouldn't hurt to prime the oiling system either.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline
Old 12-29-2006, 11:52 AM   #6
Joe67
67 is sold
Stacy David did a show on this topic with a very old truck he did.
Go through ALL of the fluids, etc. I'm not sure what else was entailed, good luck.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 12-29-2006, 12:29 PM   #7
engrdean
I really appreciate all the response. Bishops, this is probably a dumb question, but what is involved in priming the oil system?
engrdean is offline
Old 12-29-2006, 12:38 PM   #8
sick69
sick69's Avatar
to prime the oil system,,,,
remove both vavle covers
remove the distributor
install the oil priming rod into a drill down the hole where the distibuter goes onto the oil pump
(priming rod can be bought at most parts stores for 10 to 15 bucks. its just a rod that fits the oil pump at one end and a drill motor at the other)
spin the oil pump untill you see oil coming form the push rods/lifters
on gm engines the valve train is the last place to get oil before it drains back to the oilpan
if you prime the system until you get oil to the valve train the rest of the engine should be fairly oiled
hope this helps
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline
Old 12-29-2006, 12:38 PM   #9
truckdude239
truckdude239's Avatar
get an old distributer pull the cam gear off and upper components so you can get a drill on it pull your distributer out insert the modified distributer and spin it with a drill this will prime the oil system
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
truckdude239 is offline
Old 12-29-2006, 12:39 PM   #10
65-72 chevytoys
65-72 chevytoys's Avatar
It helps to get the oil through the system up through the lifters, push rods, and over the rockers and spings before start up. This makes sure all rotating parts are oiled before they start moving. The way I have seen it done is to remove the distributor, get an old dist shaft with the cam gear, attached it in the end of the drill. Then insert it into the distributor hole so the cam gear turns the oil pump with the drill.
65-72 chevytoys is offline
Old 12-29-2006, 12:40 PM   #11
cdowns
cdowns's Avatar
priming the oil system requires pulling the distributor and having a priming tool(available at autoparts stores) that is run by a drill it spins the oilpump and primes the system
cdowns is offline
Old 12-29-2006, 12:42 PM   #12
Bishops Trucks
KEEP ON TRUCKIN'
Take the distributor out and take a priming tool, (you can buy from Summit Racing for about $30.00) Stick it in the distributor hole, turn it until you feel it engage the oilpump and take a drill and spin it. You don't have to do it fast, just enough to get it to pump oil through the system. Replace the distributor and get the thing to start. If you order it from Summit, you can usually have it in 2 days time. While you are waiting you could do the things that the other guys said to do. Good Luck!
P.S.
When I was writing this there were no other responces before mine. You have a choice how you want to do it.
JIM
Old 12-29-2006, 01:03 PM   #13
bobthecop
bobthecop's Avatar
I would prime oil system, ck carefully all hoses, belts and fuel lines, don't want gas spraying all over. ck all wiring, making sure no rodent nests have been made, I've seen electrical systems all chewed by rodents. change coolant and pressure the system, ck for leaks. Change oil before priming, and drain fuel tank and get some fresh gas.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline
Old 12-29-2006, 01:29 PM   #14
engrdean
Sounds straightforward enough. Now if I just had the truck in my heated garage as opposed to my dad's front yard to work on in the rain this weekend, life would be good. Oh well, first things first. Once again, I really appreciate all the feedback. I may be getting ahead of myself, but once I get this thing running, get some fresh tires, and brakes that work, what else do I need to think about before I hit the road? Is there anything to be concerned about with the transmission or the rearend? Or do I just change the fluid and take off? Thanks for the advice, i will try and post some pictures of this beast when I can.
engrdean is offline
Old 12-29-2006, 02:02 PM   #15
engrdean
Something else I thought of. I know I need fresh gas, but I am fairly certain there is some rust in the tank. Will it be sufficient to let the fuel filter take care of it, or do I need to get the tank cleaned or a new tank altogather? Unless it will create major problems, my intentions are to put fresh gas and a new fuel filter on it and run it as is for now with the hopes of doing the blazer tank conversion sometime in the near future.
engrdean is offline
Old 12-29-2006, 02:29 PM   #16
Bishops Trucks
KEEP ON TRUCKIN'
You have one filter in line at the carb, put another filter near the tank. I don't see a problem with that. I wouldn't leave it that way past the spring. Change the tank sooner vs. later.
JIM
Old 12-29-2006, 02:38 PM   #17
krue
Designated A-hole!
krue's Avatar
Be a good time to do the tank under the bed conversion.
www.daveramsey.com
krue is online now
Old 12-29-2006, 03:04 PM   #18
Green Machine
Green Machine's Avatar
Might want to get some penetrating oil or WD40 with a tube and try to lube the valve stems and guides, the valves could be sticking/rusty in the guides. Check the pushrods where they go thru the head guides, they can rust there and chew up the heads.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline
Old 12-29-2006, 04:32 PM   #19
truckdude239
you want to remove the cam gear or your drill wont be powerful enough to spin the shaft
David fuller
2012 Subura outback
1999 honda accord
Old 12-29-2006, 05:42 PM   #20
lpaine
lpaine's Avatar
When you're finally ready to start your truck up,maybe keep a fire exstinguisher close by, just in case.....
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline
Old 12-29-2006, 05:53 PM   #21
engrdean
Thanks for the advice lpaine Assuming it doesn't turn into a weenie roast as opposed to a rebuild, I will update everyone tomorrow. Thanks again for all the advice, this is only the beginning.
engrdean is offline
Old 12-29-2006, 09:12 PM   #22
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I just started my truck after it had sat for 10 years. I did most of the stuff recommended above and then just sprayed some carb spray in the carb and it fired up. Ran a little rough but not too bad. I let it idle for a few minutes then realized the seals on the waterpump had dried out and it was leaking water. Other than that, no problems
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline
Old 12-29-2006, 09:19 PM   #23
albertarose
albertarose's Avatar
you can bypass the rusty fuel tank if you run a soft fuel line off the fuel pump to a small jerry can tied upright under the hood I did this more once to avoid running bad gas thru a unit that was parked a long time..a lot of condensation can form in a tank over 15 years..did you find a source for an under bed tank ? good luck firing that puppy up!
albertarose is offline
Old 12-29-2006, 09:50 PM   #24
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Carry a spare fuel filter with you.After that long you may need it right away.You will also want to spray a little carb cleaner or dribble a bit of fuel into the carb so you don't run the battery down when you crank it.It will take a while for the fuel pump to pull fuel to the carb.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline
Old 12-29-2006, 10:00 PM   #25
blacktruck
Super Trucker
i did this same thing you are doing. do pretty much everything these guys are saying. you'll be thanking them when it fires up and doesn't wipe a cam lobe or puke a rod up. you don't want to crank it over a lot at first. that causes excess where on the cam lobes, lifters, main crank bearings, etc... you get the idea i'm getting at? oh yeah, jerry can at the pump, i'd even go and get a new pump if it was me. plugs, marvel mystery oil in the cylinders, crank it over with breaker bar a few times just to make sure it's not binding up somewhere. pull the valve covers, dist. and prime the oil pretty good. check all the fluids, belts, hoses. it's probably gonna smoke for a bit so you might want to do a ring reseat procedure after all this time. but yeah, make sure it's got PLENTY of fuel. of course keep the extinguisher around. safety first. basically everything posted by the other wise men before me. i just wanted to post something worth reading and reiterate the importance of everything they said. good luck, be safe.
edit... if it doesnt crank right up at first, pull a spark plug, ground it on the block and make sure it's getting spark. else it won't ever fire no matter how much you try. possible causes could be hei module or bad coil if you have points.
American by birth, Southern by the grace of God.
".. you aint just whistlin' Dixie..."
Rebel till I die
blacktruck is offline
