tubular lower control arms
I want to upgrade the front suspension by putting tubular upper and lower control arms on. Has anyone done this and is it worth it. basically I am trying to take as much weight off of the front as possible so it will handle better and what else can I do to drop some weight in the front. also who makes the cheapest tubular control arms that are high quality? thanks
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom Last edited by smoked68; 12-29-2006 at 03:41 PM. Reason: add |
Re: tubular lower control arms
the ART strong Arms are heavier than your stock arms. Do a search for a-arms and you will get a ton of info.
Josh |
