Old 12-30-2006, 08:00 PM   #1
gr8dane
70 chevy c-10 6 to 5 wheel lug upgrade
I wanted to convert my 1970 chevy c-10 6 lug wheels to the 5 lug wheels.
I found a 72 fleetside w/ 5 lug but the rear axles have the leaf spring system, versus the rear coil springs that I have. Is this still possible to do without too much grief? thanks, dane
gr8dane is offline   Reply With Quote
Old 12-30-2006, 08:07 PM   #2
chevybill
chevybill's Avatar
Re: 70 chevy c-10 6 to 5 wheel lug upgrade
You need to measure the rear end of each truck (backing plate to backing plate) to determine if they are the same width.
Anything is possible, you will have to define what "too much grief" constitutes, including your mechanical skills, tools, and shop or work space.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 12-30-2006, 09:45 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Also Early Classic Enterprises sells 5-lug conversion axles for your 6-lug rearend,... if the leaf spring one doesn't work out. Check, www.earlyclassicenterprises.com
Keith
Convert to disc brakes.
Old 12-30-2006, 09:56 PM   #4
mnunn454
mnunn454's Avatar
Fortunately, my 69 was converted from 6 to 5 lugs before I got it. But from all appearances the swap is (was) simple and the axles appear to me to be the stock length. If you need me to measure mine, let me know.
Mike
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 12-30-2006, 10:06 PM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
lots of good info here
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-30-2006, 10:10 PM   #6
sick69
sick69's Avatar
if the rear ends are the same width you could just cut the spring perches off the new rearend and weld new ones on in the correct location.
not that big of a deal if you have a welder,space and time to do it.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
