Old 12-30-2006, 05:43 PM   #1
jimmydean
jimmydean's Avatar
Brake lines for disk/drum prop valve?
So I have the prop valve and the lines that run from the M/C to the valve. But the stock lines are 3/8 and mount to the bottom, where the new valve has one on the bottom (and it's 1/4") and one in the back. I have been to every parts store and nobody has a 3/8 to 1/4" reducer, or a male to male union so I can run a short line to the back.
Where can I get these parts? Did anyone else have these issues when swapping the front to discs? Man, what a pain!
jimmydean is offline   Reply With Quote
Old 12-30-2006, 06:11 PM   #2
70GMCer
70GMCer's Avatar
Re: Brake lines for disk/drum prop valve?
Maybe 70c10 (Jim) can chime in here on this. He went through the same problem last week......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-30-2006, 08:11 PM   #3
NitroMike
Active Member
NitroMike's Avatar
I ran into the same thing and got the required reducers/adapters at my local NAPA store. They always come through with the right quality pieces.
Good Luck.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 12-30-2006, 09:53 PM   #4
jimmydean
jimmydean's Avatar
NAPA was the first place I went. I will go to the bigger NAPA tomorrow and see. I figured if anyone had it, it would be them, guess just not in my little town.
Old 12-30-2006, 10:14 PM   #5
krue
Designated A-hole!
krue's Avatar
Could one of y'all post pics of your setup, 'cuz I swear I think I have mine backwards.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-30-2006, 10:59 PM   #6
jimmydean
jimmydean's Avatar
Front to front, rear to rear for 1/2 ton, reverse for 3/4 ton. There is a pic on here somewhere when I asked about hose routing.
Old 12-30-2006, 11:02 PM   #7
krue
Designated A-hole!
krue's Avatar
After doing a little reading, I think I'm gonna rob the booster/ m/c /prop valve off a 84 and put on mine, I hate the rusty, leaky m/c and ugly prop valve in the way on mine.
www.daveramsey.com
Old 12-31-2006, 10:40 AM   #8
70c10
67-72 Addict!
70c10's Avatar
Dave, I went to every parts store in town for the reducer fittings in the rear of the prop valve. I finally found it at Napa but I don't know the part number. I used two fittings (inverted flares) to make it work. The front line reducer fitting was easy to get. The brake conversion is on hold right now so I haven't been able to see if they will leak. I will post a pic of the fittings later today.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-31-2006, 11:32 AM   #9
boraxman
Keepin an eye out
boraxman's Avatar
I went through the same thing...so I ended up upgrading to stainless brake lines.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-31-2006, 04:50 PM   #10
jimmydean
jimmydean's Avatar
The back is where I'm having issues right now. I went a few towns over to a bigger napa and got the 1/4 to 3/16 reducer and a 1/4 x 8" brake line. So it looks like I'll need to do some funky 5/16 to 1/4 conversion with some pipe fitting in between.
Old 12-31-2006, 08:38 PM   #11
jimmydean
jimmydean's Avatar
So I got it all connected, but the prop valve is nowhere near mounting like it's supposed to. The prop line and bracket kit I got was about 3/4" too wide where it mounts to the M/C. Then when I got that together, the rear line was too close to the booster. Man, what a mess.
I'm guessing I will be replacing it all very soon anyway, but I will bleed it tomorrow and see if it's at least functional.
Old 12-31-2006, 08:56 PM   #12
70c10
67-72 Addict!
70c10's Avatar
Here is the pic showing the two fittings between the prop valve and existing brake line fitting. NAPA just started selling a new type of coated brake line that is bendable by hand . It's very nice and you can bend it like a pretzel without kinking it!
Jim
Old 12-31-2006, 10:30 PM   #13
pound41
Got mine at home depot in the plumbing section
pound41 is offline   Reply With Quote
Old 12-31-2006, 10:34 PM   #14
jimmydean
jimmydean's Avatar
After looking at the pic on GMC Paul's site, I noticed they are way different than the ones I got.
My guess is the ones I got are for a different year. I can't find the paperwork, so I'm not sure what they said they were for, but they sure are these.
I was able to get the 3 fittings to connect the back, it's just wicked ghetto. I'll post a pic tomorrow. I am looking to replace everything soon anyway, but this should get me on the road.
My bracket looks like the one above but my lines look like these:
No wonder they didn't fit!
