Old 01-02-2007, 01:25 PM   #1
1969k10stepside
steering stabilizers
I just got done(well,in the process of) installing a 6" lift on my swb 4x4.It has a steering stabilizer on it now but I am going to replace it.Any suggestions on what kind I should get?The truck will be a D.D./part time offroaded,not a heavy wheeler and will probably have 35's on it if that matters.
1969k10stepside is offline   Reply With Quote
Old 01-02-2007, 04:06 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: steering stabilizers
I have Rancho's single shock stabilizer kit on my 69 K20. It seems to do the trick. I believe they offer two different shocks, I got the better of the two on mine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-03-2007, 04:47 AM   #3
Mudder
Mudder's Avatar
I use ranchos
Mudder is offline   Reply With Quote
Old 01-03-2007, 09:46 AM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have a duel Procomp. The one where the are on top of each other.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-04-2007, 09:11 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I think I got a procomp one or one of similar quality and it works good. Its only a single though.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-04-2007, 09:29 PM   #6
msgross
msgross's Avatar
69k10stepside, At what point should a guy go to extra stabilizers? I have an axle with a dual setup but is it needed? I think they are rugged trail. It also has the original stock stabilizer....
msgross is offline   Reply With Quote
Old 01-04-2007, 09:54 PM   #7
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
I too would like to know the pros/cons & peoples opinions of single vs. dual stabilizers.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 01-05-2007, 12:19 AM   #8
1969k10stepside
Msgross,I dont think dual stabilizers would be needed unless you moved up to a big lift (6"+),big tires,and do alot of heavy wheeling and still use it on the road.I use a single one on the 69 w/ a 6" lift though.You running 33's and no lift really dont need dual stabilizers IMO but its your truck and is up to you.Someone else might have more to say about them and when you need duals....
Old 01-05-2007, 04:33 AM   #9
Mudder
Mudder's Avatar
years ago I had read that when you go to 35's you may have a need for duals. Going to two of them will test your gearbox. Something to think about.
Old 01-05-2007, 09:42 AM   #10
msgross
msgross's Avatar
69k10step, interested in purchasing a dual stabilizer setup? I'm gonna post it on the for sale thread soon... i can send a pic, it's an end to end system, not stacked.
Old 01-05-2007, 09:56 AM   #11
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I also heard that 35's and up is where you should consider a dual setup. No need for smaller tires. They do make a difference as my 38's were all over the place without crossover and she tracks pretty straight now.
Old 01-05-2007, 08:06 PM   #12
Zoomad75
K5Camper
Zoomad75's Avatar
I've got 35's with just a single skyjacker stabilizer. No problem here.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
