Old 01-02-2007, 06:57 AM   #1
1bad chevy
1bad chevy's Avatar
disc brake conversion
does anyone know if you can swap out the front drum brakes on a 1964 c10 with 1970 and newer disc brake off a stock 1/2 ton chevy in other words will it interchange
1bad chevy is offline   Reply With Quote
Old 01-02-2007, 12:40 PM   #2
fishmunger
fishmunger's Avatar
Re: disc brake conversion
the entire crossmember and all suspension components from 73-87 trucks will bolt in. If you dont want to swap the whole thing at the crossmember, the arms should fit too. Do a search in the 60-66 forum as this topic has been hit a lot. also check out chevytalk.com as the 60-66 forum over there is way more active than on this page. They seem to know everything over there.
Nate
fishmunger is offline   Reply With Quote
Old 01-02-2007, 02:26 PM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Im doing the full crossmember swap right now on a 64 and the crossmember almost bolts up. There are 4 bolts that do not line up. If I had it to do again I would just do the control arm swap.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 01-03-2007, 05:23 AM   #4
1bad chevy
1bad chevy's Avatar
thanks for the help guys now i know what way to go
