![]() Join Date: Feb 2000
I have removed a manual brake master from my 1970 K5 and have installed a master cylinder, booster and proportioning valve from a 1978 3/4 ton.
I removed the donor parts quite some time ago and I don't recall which reservior is supposed to feed the front as opposed to the rear. I currently have it hooked up with the front reservoir going to the proportioning valve to feed the front brake lines. Can someone with a 78'ish 3/4 ton take a look and see which reservoir feeds your front brakes? I believe your proportioning valve should be on a crossmember about below the engine fan. Here is how mine is presently ran ![]() Thanks ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 12:00 PM. |
