Old 11-09-2002, 06:15 PM   #1
nu2-72
Need help Edelbrock carb
Just went to the neighbors. He put on a 1406 and every time the engine cranks, it pushes large amounts of fuel into the intake. Each time the fuel pump cycles, it moves an ounce or more. After 3-5 seconds the cylinders hydro lock. Any ideas as to why the float is not stopping the fuel ? Any suggestions ? It is brand new out of the box.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 11-09-2002, 06:44 PM   #2
crazy longhorn
Fabricate till you "puke"
I would pull the top of the carb, & check float levels & also check for any machining trash & or stuck float needle . I had to reset the float levels on my 1407, as it ran rich enough that it would foul plugs(1 float was too high). You may also check fuel pressure if running a bigger pump. My guess is that it has a stuck needle tho.... good luck.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-09-2002, 07:08 PM   #3
bigjimzlll
bigjimzlll's Avatar
yup..longhorns right...edelbrock says no more than 5.5 fuel pressure..i have 7 right now on mine..little rich at idle but not too bad
jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
