01-04-2007, 07:31 PM | #1 |
header & motor mount pics
Hopes this helps someone, I used the tubular motor mounts from Brothers & flotech headers for the bbc swap,they fit good,the driver side has about 1/4" clearance on front header tube & the pass side you could throw a full grown house cat thru & not touch a thing.
Flowtech#31530 ceramic coated,$229.99 from Autozone Mounts,,anchor part#2267 from O'rielly's auto parts $8.00 each tubular stands from Brothers #I forget? They do hang down below the frame about an 1.5" though,may have to go to a taller tire on my truck,it's lowered 3&5 with 255/50/17 nitto's. Jon Last edited by TraderJon; 01-04-2007 at 07:43 PM. Reason: add more info |
01-04-2007, 07:47 PM | #2 | |
YES_____NO
Re: header & motor mount pics
, Good pics and info..
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
01-04-2007, 08:11 PM | #3 |
Thanks Mongo
I thought there were a few us on here doing the sbc to bbc swap ,so i threw that tidbit out there,now if i can figure out the power steering brackets we'll be cruising again in a couple weeks. Jon |
01-04-2007, 08:30 PM | #4 |
NOT REALLY BANNED!
How hard were the tubular mounts to install?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
01-04-2007, 08:40 PM | #5 |
Didnt have to drill any holes,bolted right in,I shoulda mentioned it's a 72 frame,with 67 sheetmetal, I think the original 67 frames are not carved out at the motor mount area,there straight & will interfere with the stand mounts.
Also learned the hard way,leave all the bolts loose till you get the trans mount pad stabbed in the hole,gives you some wiggle. Jon |
01-04-2007, 08:45 PM | #6 |
I appreciate you sharing this, I bought a set of flowtechs from summit for a 72 big block truck to go in my blazer. Now that you said they hang below the frame 1.5" I think I will need to get some diffrent ones.
01-04-2007, 08:50 PM | #7 |
Yeah they hang down a lil further than the sbc did,,I'll try to get a side view pic for you,may not be to accurate ,it's still up on jackstands.
Thanks Jon |
01-04-2007, 08:50 PM | #8 |
Throbbing Member
I have a 67 doing the BBC swap in. Which holes did you use to mount the towers in? Also what is the white stuff under the upper tower mount?
Thanks |
01-04-2007, 09:01 PM | #9 |
I used the front v8 holes ,,I marked the old sbc stands before I pulled em with a paint stick for reference ,I get the crs stuff sometimes..
Jon |
01-04-2007, 09:07 PM | #10 |
JKade
Heres a pic,It may even hang lower than 1.5",,I always go by the collector height,usually thats the first part to drag the dirt? Now that i think about it,,thats a 3' collector. Jon Last edited by TraderJon; 01-04-2007 at 09:09 PM. |
01-05-2007, 03:29 PM | #11 | |
Could you please post that PN for the tubular mounts?
I flipped through my brothers catalog 4 times and didnt see anything. Thanks, Mitch
01-05-2007, 03:34 PM | #12 | |
Nevermind, here they are.....
http://brothersonlinestore.com/prodi...number=ESM6372 These arent in the catalog for some reason.
