Old 01-05-2007, 11:01 PM   #1
blue betty
Drum brakes??
I just overhauled my entire braking system, new everything rubber hoses, steel lines, wheel cylinders, master cylinder, spring kits, drums and shoes. My problem is I cant seem to get the shoes to sit properly, they wont close in all the way.At the top their still 2cm away from the main bolt. any ideas why?
blue betty is offline   Reply With Quote
Old 01-05-2007, 11:13 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Drum brakes??
Could you possibly post a pic?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-05-2007, 11:18 PM   #3
blue betty
Re: Drum brakes??
Old 01-05-2007, 11:25 PM   #4
blue betty
Re: Drum brakes??
Tried using an existing picture didnt work, wife broke the camera on the weekend
Old 01-06-2007, 12:32 AM   #5
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: Drum brakes??
Is the star adjuster all the way in? Are the pads upside down or reversed front to back?
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-06-2007, 01:42 AM   #6
blue betty
Re: Drum brakes??
the star adjuster is all the way in and the shoes are on properly.
Old 01-06-2007, 02:05 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Drum brakes??
Here is a thread with pics that may help.
http://67-72chevytrucks.com/vboard/s...ht=brake+shoes
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-06-2007, 04:08 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Re: Drum brakes??
Stupid Question but is the emergancy brake on?
Did you do just one side at a time?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-06-2007, 09:32 AM   #9
blue betty
Re: Drum brakes??
Thanks for all the help guys, The emergency brake is off, but now it doesnt work when applied and it did work b4.the star adjuster is all the way in so the drum will move because the brakes our out at the top still
Old 01-06-2007, 12:33 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Drum brakes??
you tried squeezing the shoes in with your hands? There may be fluid in the brake cylinder that needs pushed back in. I find this almost common on a system that's been apart for a while
Old 01-06-2007, 12:58 PM   #11
kwmech
Re: Drum brakes??
Even though the park brake is off, the cables may be partially stuck/frozen.
Old 01-06-2007, 02:34 PM   #12
Longhorn Man
Re: Drum brakes??
that would spread the bottom, not the top
Old 01-06-2007, 05:14 PM   #13
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Drum brakes??
Assuming you matched up the new shoes with the old ones to make sure you had the right parts (you didn't get them at Auto Zone,did you?),then put on some clean gloves and just squeeze and shake the hell out of them. Sounds light the back edge of the shoe is catching on the ridge in the backing plate.-cougar
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-07-2007, 11:34 AM   #14
cooters
Re: Drum brakes??
THE PROBLEM IS THE STAR WHEEL ADJUSTER CANNOT BE IN ALL THE WAY. yOU TURN THE STARWHEEL OUT TILL THE SHOES JUST TOUCH THE DRUM. tHIS IS WHY THE EBRAKE WONT WORK CAUSE THE TRAVEL OF THE CABLE IS NOT ENOUGH. kEEP IN MIND HOW FAST THE BRAKES GRAB WHILE PRESSING THE BRAKE PEDAL IS BASED ONLY FROM ADJUSTING THE REAR STAR WHEEL ADJUSTER IF YOU HAVE DISK FRONT BRAKE. ALSO CHECK YOUR SPRINGS THAT WRAP AROUND THE ANCHOR PIN AS THEY ALSO PULL THE SHOES TO WHEEL CYLINDER
cooters is offline   Reply With Quote
Old 01-13-2007, 09:06 PM   #15
blue betty
Re: Drum brakes??
Thanks guys for all the help. It ended up being my Emergency brake, the horizontal bar is what was keeping my brakes apart, it must have been pulled with the drums off. ( i was doing new guages as well). again thanks for all the help and im excited to have it back on the road, blue betty
