Old 01-01-2007, 07:06 PM   #1
mnunn454
mnunn454's Avatar
Adding Cargo light to a 69 C-10
Looking at LMC's catalogue, it appears cargo/3rd brake lights (at the top of the cab above the back glass) didn't appear as optional on Chevy/GMC trucks until 1970. I sure would like to add one to my 69 C-10 while I've got it torn apart upgrading the interior.
Four Questions:
1) What should I buy?
2) Since the cabs are the same shape, is it as simple as sawing a correctly sized and placed hole in my 69 cab and mounting/wiring a 70 light in it?
3) Anyone done this before?
4) Anyone got a picture of a 70-72 with the light factory removed so I can see the hole's shape and size?
Thanks,
Mike
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-01-2007, 07:34 PM   #2
JimKshortstep4x4
Re: Adding Cargo light to a 69 C-10
I have installed a cargo light in a cab that did not have one. It is easy and there are instructions in the Assembly manual if you have one. When I installed mine I set up a separate toggle switch under the dash instead of installing the factory switch. I wanted t be able to turn the light on at any time, not only when the courtesy light was on.
I can photo and post the assembly manual instructions if you need them.
Jim
Old 01-01-2007, 08:05 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
LMC is full of inacuracys, and that is one of them... Mid 69 was when they were introduced.
Some one on here was offering a template at one point as to where and what size to cut the hole... hopefully some one can chime in if they remember who it was?
Old 01-01-2007, 08:15 PM   #4
mnunn454
mnunn454's Avatar
Jim
Thanks Jim. Yes, that'd be great.
Post the info for all, or e-mail me directly at mnunn454@cox.net
Thanks.
Mike
Old 01-01-2007, 10:04 PM   #5
CG
BlahBlahBlah
Page 12 of Rokcrln Project Penicillin build up shows his cut out for the cargo light. Click the link below and go to page 12 ( I think it was 12, lol )
http://67-72chevytrucks.com/vboard/s...d.php?t=188993
Old 01-01-2007, 10:22 PM   #6
sdkid
That was Lakewood90712. He was supposed to send me one, but I never got it. Maybe a comm error. Anyway, his profile shows last visit of nov something. Maybe someone else could make a template. I know I would still like one.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-02-2007, 01:01 AM   #7
FarmTruk
In Memoriam...
FarmTruk's Avatar
As another option...
Another boardmember, 68gmcdually, added a late model HCM brake light/cargo light combo to his 68 Extend-a-cab. I'm sure this entails a BUNCH of fab work, but it sure looks cool as all get out.
Linky to his build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=149156
Also, here's a couple of pics of the mod from his buildup thread...
Hope he doesn't mind me posting his pics, but I do want to give him props for a job well done.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-02-2007, 11:53 AM   #8
Mudder
Mudder's Avatar
My 67 had one when I got it and it was wired into the courtesy lamp. I added one to this cab and it's just a small oblong hole.
Mudder is offline   Reply With Quote
Old 01-02-2007, 01:34 PM   #9
MisterMan
MisterMan's Avatar
you crazy... im patcing mine. i hate it.... but.. take demintions of the bottom of your read window... devide by 2. this is your 0..... measure your light, devide by 2. this is your other 0.... line up marks.
MisterMan is offline   Reply With Quote
Old 01-02-2007, 03:11 PM   #10
68gmcdually
68gmcdually's Avatar
Fine by me, it wasn't that bad in the fabricating end of it. Cut the panel out of the donor '01 silverdo and welded it into mine, just need to actually hook it up now.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 01-02-2007, 07:21 PM   #11
67chevemall
67chevemall's Avatar
Went a little nutty and put one under the hood.
Lights the whole bay up.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-02-2007, 07:51 PM   #12
Longhorn Man
shoulda put that sucker on the hood so it shines on the engine instead of in your eyes.
Old 01-02-2007, 09:44 PM   #13
67chevemall
good call. I had a hole all ready there in the fender. needed to fill it with a bolt.
Old 01-02-2007, 10:23 PM   #14
FarmTruk
In Memoriam...
FarmTruk's Avatar
Any pics of that light on at night with the hood CLOSED...bet it'd be a kewl effect.
(hmmm... mood lighting?)
FarmTruk Pics Here
Old 01-02-2007, 10:38 PM   #15
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Adding Cargo light to a 69 C-10
now thats a good idea. if ya hooked it up to the brakes also then thats cool as he!! !!!
QKENUF4U is offline   Reply With Quote
Old 01-03-2007, 01:11 AM   #16
Longhorn Man
just remember to wire it to the brake light switch... and not to one of the brake lamps. You'd look like an idiot with that sucker blinking with a turn signal.
Old 01-03-2007, 12:25 PM   #17
68gmcdually
It will be hooked up to the stop light switch. The hitch cover light is wired into the right signal light, didn't want to have to have the trailer brakes energizing every time I hit the brakes just to light up a bulb.
James Bellwood
Old 01-04-2007, 08:02 PM   #18
mnunn454
mnunn454's Avatar
Should have mentioned initially that I don't want to repaint the exterior, so welding in late model sheet metal is a no-go. Jim K. was kind enough to send me exact measurements for cutting in the hole. I'll order the light assembly soon. Anyone know if I'll be able to find a custom one with brake light included? Thanks for the underhood light idea. I may wire an underhood light in along with the cargo light. That way my battery can run down twice as fast when I forget to turn it off!!!
Old 01-04-2007, 08:23 PM   #19
68jimmy
68jimmy's Avatar
Don't know if they came on gmc's but I liked the look and tackled the project on my 68 gmc. I had a 72 c-10 that had the cargo light so I removed it took some measurements and broke out the angle grinder. Unfortunately I don't have my measurements but here a couple of pics...
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 01-04-2007, 08:34 PM   #20
FarmTruk
In Memoriam...
FarmTruk's Avatar
Mnunn...Yep, guess you don't want to mess up that paint. Well, there's a few good ideas here for you as well as others (including me ) to use if/when we may want to install such a light.
BTW...is there any way to post the dims that Jim K. supplied, just to increase the knowledge base?
FarmTruk Pics Here
Old 01-05-2007, 07:56 PM   #21
mnunn454
mnunn454's Avatar
Mnunn............
Here it is. Thanks again Jim.
Mike
Old 01-05-2007, 07:58 PM   #22
mnunn454
mnunn454's Avatar
68jimmy,
Nice Job!!!
Old 01-05-2007, 10:11 PM   #23
badpeanut
Not a bad nut after all..
badpeanut's Avatar
What is the best path to route the wires, and what is the easiest way to get them in place?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-05-2007, 11:07 PM   #24
FarmTruk
In Memoriam...
FarmTruk's Avatar
Mike
Yes, thanks Jim K. and mnunn. Is that from the Service Manual or the Assembly Manual? Man, I gotta get one of those.
FarmTruk Pics Here
Old 01-06-2007, 10:11 AM   #25
mnunn454
mnunn454's Avatar
FarmTruk,
Jim's email to me referenced the assembly manual.
