Living In The Past
Re: Phantom 68 Longhorn with AC and 396&400
You listed your block number in 2 different posts but the second time you listed it is not the same as the first. but neither way you listed it match any numbers from mortec. Here is some numbers copied from the mortec site. 340220.....427T......68-85...4-bolt
345014.....454.......70-86... 346236.....454.......75-76...2-bolt 359070.....454.......70-90... 361959.....454.......73-90...2 or 4 bolt 364776.....427T......68-85...4-bolt 364779.....366T......68-90...4-bolt 399204.....509.......70-71...4-bolt, Alum., CanAm, 4.5" bores, Cylinder liners 399293.....366T......77-78...4-bolt 473478.....427T......77-90...4-bolt 3782870....427T......68-76...4-bolt 3824553....366T......66-67...4-bolt 3855961....396.......65-66...2 or 4 bolt 3855961....427.......66......2-bolt 3855962....396.......65-66...4-bolt 3855977....366T......66-73...4-bolt 3869942....427.......66-67...2 or 4 bolt 3902406....396.......67......2 or 4 bolt 3904351....427.......67......2 or 4 bolt 3904354....366T......66-76...4-bolt 3916319....366T......68......4-bolt 3916321....427.......68......2 or 4 bolt 3916323....396.......68......2 or 4 bolt 3925521....427T......68-85...4-bolt 3935439....427.......68-69...2 or 4 bolt 3935440....396.......68-69...2 or 4 bolt 3937724....366T......68-85...4-bolt 3937726....427T......68-84...4-bolt 3946052....427.......69......4-bolt, Alum. ZL-1, Mark IV 3946053....427.......97-up...4-bolt, Alum. ZL-1, 2nd version, Mark IV 3955270....427.......69......2 or 4 bolt 3955272....396.......69......2 or 4 bolt 3955274....366T......68-85...4-bolt 3955276....427T......68-73...4-bolt 3963512....427.......69......2 or 4 bolt 3963512....454.......70-76...2 or 4 bolt 3969852....366T......68-84...4-bolt 3969854....396.......69......2 or 4 bolt 3969854....402.......70-72...2 or 4 bolt 3969858....427T......68-84...4-bolt 3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps 3999290....396.......68-69...2 or 4 bolt, Truck 3999290....402.......70-72...2 or 4 bolt, Truck 3999290....402.......72......2 or 4 bolt, Passenger 3999293....366T......68-90...4-bolt 3999294....427T......68-84...4-bolt |
