Old 01-07-2007, 02:56 AM   #1
e rock
Removing a buggered ignition switch cylinder?
My truck is finally back in my driveway, but I had to get it towed home because the mouthbreathers that stole it screwed up the keyhole. Since my key doesn't work, I can't remove the cylinder to install a new one. At least, I don't know if there's a way to do it.
I tried using a variety of screwdrivers and such, but no luck. Apparently I would suck at being a car thief.
I'm hesitant to take the drill to it, but that may be the next step if I can't figure out how to get the cylinder out without damaging the switch housing.
Thanks,
Eric
e rock is offline   Reply With Quote
Old 01-07-2007, 03:02 AM   #2
68shortfleet
Re: Removing a buggered ignition switch cylinder?
I need this answer also. I didnt get keys with the A/C cab that i got.
Jason
68shortfleet is offline   Reply With Quote
Old 01-07-2007, 03:05 AM   #3
matthufham
it has a bezel on it. the lip on the front plus the spacer on the back sandwhich it to the dash. the bezel is really thin stuff, so i took a cutoff wheel and cut like 20-30 cuts on it's lip and slowly broke chunks off of it until the whole ignition set came out the rear of the dash hole. you'll need a new switch, new lock cylinder, a new bezel, and you'll probably be able to get your old spacer off, so you can reuse that.
matthufham is offline   Reply With Quote
Old 01-07-2007, 08:15 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
You are down to a drill or a saw-zaw. Either way prepare yourself to have to buy a new lockset, and ignition housing. The cab you want ot keep.......go under the dash with a saw-zaw and cut the ingnition housing in half. Disconect the wiring plug from it first. The cab that you dont want to keep........unscrew the bezzel as far as it will go and then pop it with a heavy screw driver and a hammer.
Others have had luck drilling the cylinder out, but every time I try it I end up messing up the housing anyway. It quicker to cut it in half and start from fresh.
A new lock housing...$10 on ebay
complete lock set.....$35
72freak is offline   Reply With Quote
Old 01-07-2007, 11:00 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
FAQ;
http://67-72chevytrucks.com/vboard/s...d.php?t=123712
Old 01-07-2007, 12:35 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Jason
If the door locks are still in your A/C cab this thread may help you.
http://67-72chevytrucks.com/vboard/s...oc#post1837269
LockDoc
Leon
Old 01-07-2007, 07:22 PM   #7
dbcox
dbcox's Avatar
jab something in it thet will stay to pull it out get a paper clip stick in that little hole and turn left and pull it should come out i didnt have a key for mine i got a new cylinder jabbed a old key in it and pulled it out
dbcox is offline   Reply With Quote
