Old 01-08-2007, 12:21 AM   #1
HotRod73
HotRod73's Avatar
Wheels
I've got a 87 Gmc with 5 lug... Is 5x5 the only bolt pattern that will fit?
and i have stock rallys right now 15" i want to keep the tires do you think stock wheels are 15x8 or what?
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 01-08-2007, 12:34 AM   #2
82c10
needin' money
Re: Wheels
yep, or uni-5 lug wheels, stock wheels are either 15x7 or if you are lucky enough they can be 15x8, need a pic to tell though
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 01-08-2007, 12:40 PM   #3
kevinr1970
Re: Wheels
My experience has been that trucks came with 15x8's and van came with 15x7's. Your experience may vary though?
If you look at the rim it should have the size stamped on it somewhere. I think on the rally's it is stamped on the back side but it might also be close to the valve stem hole.
Either way, its difficult to see if the rim is dirty.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-08-2007, 05:03 PM   #4
hiway
Mad Scientist
Re: Wheels
I think most of the 80's trucks were 7"ers.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 01-08-2007, 08:38 PM   #5
68Stepbed
68Stepbed's Avatar
Re: Wheels
Here is my 86 with 8" rallies and 255/70/15 tires. Does yours look like this?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-09-2007, 01:27 AM   #6
Low84
Low84's Avatar
Re: Wheels
Well, somebody correct me if I'm wrong but the 15x7 wheels have the 2 inch deep "beauty ring" as opposed to the 15x8 wheels which have the 3 inch ring instead.
An easy way to tell without measuring the ring to figure out which one it is, is like this: The 2" doesn't go completley around the valve stem in essence its only a "U" around the stem. The 3" does go completley around the valve stem, kind of makes an oval around it.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 01-09-2007, 02:13 AM   #7
HotRod73
HotRod73's Avatar
Re: Wheels
what is the biggest size rim i can install without modifying suspention or anything? 20s?
Old 01-09-2007, 06:41 PM   #8
82c10
needin' money
Re: Wheels
yes, you can even fit 22's , it is all about the offset, and the tire size, there is no real answer to the biggest wheel you can fit, what are you looking to do and we can lead you to what you need
Old 01-09-2007, 08:11 PM   #9
HotRod73
HotRod73's Avatar
Re: Wheels
just want some shiney rims i am thinkin 20's MAYBE 22's what offset would i need and what kinda tires?
Old 01-10-2007, 02:16 AM   #10
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Wheels
If you go with larger wheels, you may end up reconsidering a suspension drop. If so, you, may want to size your wheels to tuck, say like ~5" bs on a 10" wheel in the rear and a ~5" - ~5.25" bs for a 8" wheel in the front. What type of stance are you after? (Stock stance with 20s or 22s?)
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-10-2007, 02:28 AM   #11
HotRod73
HotRod73's Avatar
Re: Wheels
yeah i just know nothing bout wheel sizes
Old 01-10-2007, 07:41 AM   #12
bigblock73
yeller
bigblock73's Avatar
Re: Wheels
You may be incorrect. I just purchased a set of rally wheels with the skinny trim rings from a junkyard...I am pretty sure they are 8" wheels. I can't check however as they are in the back of my 'Burb in storage. I'll let you know in the spring.
bigblock73 is offline   Reply With Quote
Old 01-10-2007, 08:28 AM   #13
68Stepbed
68Stepbed's Avatar
Re: Wheels
I'm not bashing the big wheel thing, but I wouldn't go 20's or bigger unless you do something with the suspension. Chip Foose said it best: You can't put a set of 20" inch wheels on just anything. You have to build the car around the wheels. I don't think 20's with stock suspension would look good at all. A set of 17's would look better if you want bigger wheels.
Just my .02
Matt
Old 01-10-2007, 12:07 PM   #14
HotRod73
HotRod73's Avatar
Re: Wheels
anyone got a pic with a 73-87 with eagle alloys? like the 028 model... i love them (5 star) i like blingy wheels but i like the race look better... i dont know what im gunna do... lol
just looking for something under $600 bucks for wheels
Old 01-10-2007, 06:57 PM   #15
82c10
needin' money
Re: Wheels
yeah someone does, you could get the jegs-weld knockoff's for less then that, as for the 028 there is a guy that is/was in one of the armed forces, that either is fatguy or bought a truck from fatguy if i recall, do a search, and you can probably find it, it is an 86 gmc i believe
Old 01-10-2007, 07:16 PM   #16
84 400
Sb 400 club
84 400's Avatar
Re: Wheels
Give your local cregislist a try lotts of wheels on there cheap and close to you so no shipping.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-10-2007, 07:32 PM   #17
84 400
Sb 400 club
84 400's Avatar
Re: Wheels
his online name is Crank. if i rember right he bought the truck from fat guy. here is one of his threads with picturesof the wheels.
http://67-72chevytrucks.com/vboard/s...ghlight=blazer
1985 C10 LWB Sold
Old 01-10-2007, 10:10 PM   #18
HotRod73
HotRod73's Avatar
Re: Wheels
the jegs weld knock offs dont have 5x5 though i always see 5.475 and 5.5/5 or something like that doesnt it have to be 5.5
Old 01-12-2007, 03:15 PM   #19
HotRod73
HotRod73's Avatar
Re: Wheels
I've decided to buy Eagle Alloy 028 series... Now my question is... What size? I want to keep it 15" for now... so i was told i should try 15x8 up front and 15x10 in the rear, will this fit without any modifications?? is that too wide? and is that a good option??? give me some suggestions on which size
Old 01-12-2007, 04:20 PM   #20
82c10
needin' money
Re: Wheels
you have got ps (power steering), i would probably go all 15x10's or 15x8's with that style wheel
Old 01-12-2007, 06:47 PM   #21
HotRod73
HotRod73's Avatar
Re: Wheels
which would look better? and yes it has power steering..
Old 01-12-2007, 07:56 PM   #22
68Stepbed
68Stepbed's Avatar
Re: Wheels
What size tires are you running? 8's all around or 8's and 10's would look best IMO.
Matt
Old 01-12-2007, 08:14 PM   #23
Crank
Crank's Avatar
Re: Wheels
Yea, I had those wheels on my truck for a couple of months, but as soon as I bought new tires, I put my rally's back on. Rallys are great if you ask me, a nice Blingy beauty ring and a new center caps and they stand out as well as a set of aluminum wheels. Do you have any pictures of your truck as it sits? Anyway, Rallys are cheap, plentiful and WILL FIT, no questions.
Brandon
Crank is offline   Reply With Quote
Old 01-12-2007, 10:39 PM   #24
HotRod73
HotRod73's Avatar
Re: Wheels
i have the original chrome rallys with beauty rings and chevy center caps right now i have a few pics posted around this group... i plan on sellin em for whatever i can get and get these eagle 028 series wheels
Old 01-13-2007, 12:23 AM   #25
82c10
needin' money
Re: Wheels
all 10's if you like the look
