Old 01-08-2007, 08:40 PM   #1
Bob Moore
Brake pedal question
I have a question on the brake pedal. Is there a difference between manual and power of where the rod attaches to the pedal arm? I have the booster with brackets and the correct linkage rod through the firewall but just curious if the attachment hole is different for manual vs. power. I have 5 pedal assem's that all have the same hole. I'm sure they are power pedals but just curious if there is a difference.
TIA - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-08-2007, 09:50 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Brake pedal question
the pedal is the same p/n for manual or power assist
Old 01-08-2007, 09:57 PM   #3
gyjackson
Yep, pedals are the same, but beware of the mal-adjusted master cylinder rod. I did the swap with mine and the rod was adjusted a bit long. It took me forever to figure out why the brakes began to tighten up after driving (and stopping) repeatedly.
gyjackson is offline   Reply With Quote
Old 01-08-2007, 10:09 PM   #4
msgross
msgross's Avatar
I have heard of guys mounting the rod lower on the brake arm after a power upgrade but don't know if it's necessary. Something about not needing as much pedal to stop and it makes the brakes less touchy.
msgross is offline   Reply With Quote
Old 01-08-2007, 11:57 PM   #5
qksilver
generally the P/B rod will mount about an 1 1/4 lower than where a manual rod would mount
qksilver is offline   Reply With Quote
Old 01-09-2007, 12:34 AM   #6
GMCMAX
Active Member
GMCMAX's Avatar
I was curious as well, my 2 conversions are touchy, almost kissed the windshield on the first stop, but after 24 years of having to stomp the pedal, it takes some retraining...
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 01-09-2007, 01:21 AM   #7
MT1972cheyenne
MT1972cheyenne's Avatar
QKsilver, what do you base that info on?
MT1972cheyenne is offline   Reply With Quote
