01-09-2007, 01:36 PM | #1 |
how hard?
how hard it it to remove a bed from one of our trucks? i was looking to go remove one from a truck in the junkyard what do i need to do it?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-09-2007 at 01:37 PM. |
01-09-2007, 02:00 PM | #2 |
Re: how hard?
There should be just 8 bolts that hold it down through the bed floor and then the wiring.
01-09-2007, 02:42 PM | #3 |
huh ???
Re: how hard?
You'll also need at least 3 other friends or a forklift. These beds aren't light...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
01-09-2007, 02:50 PM | #4 |
THE VILLIAGE IDIOT
Re: how hard?
make darn sure you take a really good rust penatraing oil..i used pb blaster or something like that a few months ago..almost all of the bolts came off by hand,,only 2 broke off..the stuff im talking about stinks,,but darn it sure worls good...the can is white with all different color writing on it..cost alot more than wd40,,but id is worth the price..or try the gibbs stuff they are talking about on the boards...havent used it myself but will be getting some soon to try out..im getting older i guess,,and realize sometimes you need to spend more money to get something to make things easyier
honestly honey,,i have no idea how that truck got here. |
01-09-2007, 02:50 PM | #5 |
Re: how hard?
When I removed the bed (wood floor), I ended up twisting bolts off, grinding a few off. Bolts on the inside of the bed don't give you much to get ahold of should they start to turn all the way through. I'd take a chissel, etc.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
01-09-2007, 05:16 PM | #6 |
Re: how hard?
A cordless saws-all works really good on those frozen bolts too. I got lucky and only had to cut one of mine, and that was after 24 hours with penetrating oil. Other than that, it was real easy. Once I called three neighbors over to remove it.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
01-09-2007, 07:29 PM | #7 |
Re: how hard?
a torch & a few friends...
