Old 01-10-2007, 12:10 PM   #1
Myself
Questions about '71 engine and trans.
I found a '71 Longhorn that the guy says is in good condition. It has a big block and auto trans. Is this most likely a 402 and TH400? Will it be a 4 bolt main? I believe the truck has ps, pb, and a/c also.
Myself is offline   Reply With Quote
Old 01-10-2007, 12:16 PM   #2
71chevylowrider
71chevylowrider's Avatar
Re: Questions about '71 engine and trans.
all you need to do is talk to LongHorn man, he knows Longhorns like you wouldn't beleive.
71chevylowrider is offline   Reply With Quote
Old 01-10-2007, 12:16 PM   #3
71chevylowrider
Here's his website for instance
http://www.longhorntrucks.freeservers.com/
Old 01-10-2007, 12:59 PM   #4
kevenj
If it's the original engine/trans combo it should be a 402 (marketed as a "400") and TH400. Easiest way to tell on the trans is a TH400 uses and electric kickdown while the TH350 has a kickdown cable. Also the pans are different - - hard to describe the 400 pan but it's an "irregular" shape while the TH350 pan is basically square with one corner cut off.
I do not believe the 402's in trucks were 4 bolt main but I could be wrong. I have a 4 bolt main 454 in my boat and there is a large pipe plug in the block just above the oil filter. I have been TOLD that all 4 bolt main big blocks have this plug and 2 bolt mains do not. I have nothing to back that up, just what a guy told me that usually is not full of B.S. so I believed him :-)
kevenj is offline   Reply With Quote
