01-10-2007, 02:52 PM | #1 |
Spanked once
More on gas tanks
The options plate on my 71 C10 says it has heavy suspension and it is a Sport truck, it does not list the two auxiliary tanks under the bed one on each side behind the cab. I have been lurking and looking here and no one has mentioned this set up. Are these factory items and can I get a sending unit for one of them so I can do away with the seat tank?
Thanks, Richard |
01-10-2007, 03:28 PM | #2 |
Re: More on gas tanks
Those are common,and I'll bet they were dealer add-ons. Mine all still work but the side tanks didn't come with sending units.I've heard that some did,with a switch on the dash to switch between tanks.Someone else should elaborate on this.
If you plan to use those side tanks,you might need to have them serviced,or at least use a large in-line fuel filter.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-10-2007, 06:34 PM | #3 |
My truck has the three tanks. There are 2 switches in my truck. One on the dash for the gas guage and 1 in the floor for switching tanks. In the future, I will be taking the one in the cab out and use the (2) 18 gallon "saddle" tanks in the the bed. I assumed that they all have sending units in them. Maybe they don't. What is the the easiest way to tell?
01-10-2007, 07:32 PM | #4 |
On mine it was easy;just one little brown wire going under the door sill which comes from the cab tank.No other wires coming out of the side tanks.
01-11-2007, 12:07 AM | #5 |
Spanked once
That's interesting to know, I'll check tomorrow for any wires. The only wires I've seen so far are for the cargo and inside light. If one tank had a sender that would be sweet.
