Old 01-04-2007, 10:03 PM   #1
LorcinLS1
Speedo calibration
My speedo is off. At low speeds 40 and under its 5 mph off. when i am above 70 its 10 mph off. the truck is a t-350 3.73 gears with 275/60/15 tire. does anyone know what speedo gears should be in the tailshaft housing.
LorcinLS1 is offline   Reply With Quote
Old 01-05-2007, 10:35 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Speedo calibration
Here's a good site that'll help you determine which speedo gear you need.
http://novaresource.org/speedo.htm
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-05-2007, 10:47 PM   #3
joeymarkgraf
joeymarkgraf's Avatar
Does anyone know if pulling out the shaft and greasing it works? I've heard that, but I'm skeptical...
joeymarkgraf is offline   Reply With Quote
Old 01-05-2007, 10:55 PM   #4
msgross
msgross's Avatar
carry a GPS..the only ticket that I have ever had was due to my speedometer being off because of my larger tires on an S-10....the excuse didn't work!
msgross is offline   Reply With Quote
Old 01-11-2007, 12:35 AM   #5
jimfulco
The short answer is no. It might help if your speedo needle wiggles, though.
jimfulco is offline   Reply With Quote
Old 01-11-2007, 12:46 AM   #6
poncho_villa
poncho_villa's Avatar
The wife says it works but I too am sceptical.:hit2:
poncho_villa is offline   Reply With Quote
