#1 | |
Re: Lift questions????
But the initial measurement from hub to fender was 23-1/2 and now is 23-1/4? I was thinking that maybe the 2" lift in the front was achieved by using a "helper" spring. If this is the case then maybe I need to put my original springs (120k) with the helper back in place of the parts truck springs (240k).
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 01-11-2007 at 04:05 PM. |
Took some pictures today. Don't know if it will help to answer my questions though?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 10-04-2007 at 11:41 PM. |
Also, I was looking at the springs and saw that both sets of springs are two leaf leaf-springs.
The set I put on my '86 (the blue one) have a thick "helper" leaf on the bottom of the pack. Would this helper spring give a 2" lift to otherwise stock springs?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
