Old 01-15-2007, 11:46 AM   #1
Crank
Crank's Avatar
Anyone ever installed latermodel seats???
Well I'm just brainstorming again I guess, but I was looking thru some of my pictures when I saw this picture of this Blazer, and as much as I want to keep a bench seat, I just dont think they would be as comfortable as these buckets, plus there would be added storage space with the console. So what all would be involved in changing to these seats? I'm assuming I'd have to drill new holes in the cab to mount these? Does anyone know or think if the brackets themselves would have to be modded? Thanks folks
Brandon
Crank is offline   Reply With Quote
Old 01-15-2007, 01:35 PM   #2
boatpuller
boatpuller's Avatar
Re: Anyone ever installed latermodel seats???
i would be interested in some info on 2000 and up style silverado or tahoe power buckets.if anybody has done this?
boatpuller is offline   Reply With Quote
Old 01-15-2007, 01:56 PM   #3
82c10
needin' money
Brandon
yes, their has been people who have done this, there screennames do not come to mind though, the 99+truck seats are bolted down at a different angle if i recall directly, and you will have to fabricate mounts, also there was something to do with safety, since the seatbelts are made into the seats, if i get time later i will look for the post
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 01-15-2007, 06:28 PM   #4
Jonboy
Slots go on anything!
Those pics are of those seats in a Blazer. Note the floorpans are flat, instead of having the hump in them. If you were to use the factory brackets, the seats would sit way too high for a pickup, but would probably work fine in a Blazer.
Jonboy is offline   Reply With Quote
Old 01-15-2007, 07:55 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
Jonboy's nailed it right there. I've installed 2002 Silverado buckets in my 75 Blazer so I can vouch for the mounting of the Silverado seats. The stock bracketry is not removeable and because of this would have the seats sitting 5-6" higher than normal in a pickup due to the hump in the floor.
I suspect the reason for the complex brackets is because of the integral seat belts and needing to be able to take the force of impact in a crash. One might be able to get creative and cut the snot out of a set, but it might not be worth it. From what I've seen and read, buckets out of a 88-98 NBS truck fit easier (4wheel and off road mag had a write up on it a few years back).
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-15-2007, 09:06 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I am working on putting seats out of a 98 Suburban in my 68 Chevy. I cut and fabriacted the brackets to fit my floor. ANYONE have an idea what that console in the picture came out of? That kind of fits my idea for my truck.
Old 01-15-2007, 09:09 PM   #7
mcssls
the safety issue with seat belts built into the seat is that the floorboard needs to be reinforced if you are not using factory mounting points. That way if in a wreck the seat doesn't become an ejector seat with you seatbelted to it still.
mcssls is offline   Reply With Quote
Old 01-15-2007, 10:50 PM   #8
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
NBS truck?
-- Will
killthewabbit is offline   Reply With Quote
Old 01-15-2007, 10:52 PM   #9
kevinr1970
Originally Posted by killthewabbit View Post
NBS truck?
New Body Style?
I think...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-16-2007, 07:05 AM   #10
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
would placing a 1/4 inch steel plate on the outside of the floor work goos enough to keep the seat from braking loose in a wreak..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-16-2007, 12:01 PM   #11
Zoomad75
K5Camper
Zoomad75's Avatar
Ding ding- NBS is new body style (88-98)....
Yes, the floor needs some beefing up to gain some strength. I used 1/4" steel as my brackets to bolt to the seats and then to the floor.
Rob Z.
Old 01-16-2007, 01:40 PM   #12
tom coop
tom coop's Avatar
console looks like a probe or eclipse to me
tom coop is offline   Reply With Quote
Old 01-16-2007, 03:19 PM   #13
gflo383
i was going to guess mid to late 90's ford Exploder... for the center console.
1986 IROC-Z lS1/T56 Moser 9" 78mm Turbo
1968 C10 step side, 5.3 Maggnacharger TVS1900 6L80E
2009 CCSB 5.3/6L80 4x4
http://members.cardomain.com/gflo383
gflo383 is offline   Reply With Quote
Old 01-17-2007, 01:07 PM   #14
Jonboy
That looks like a 99-2000 Denali/ Escalade console.
Old 01-17-2007, 10:56 PM   #15
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
i was told late model chrysler seats slide in there pretty easily with little modifications.
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 01-19-2007, 12:25 AM   #16
wildmanaaron
I have the 99-Up Silverado seats sitting in my Blazer right now. The seat tracks lined up well with a few of the holes in my floorboard, but not through all of them. I had to drill some holes in my floorboard.
I also bought a 3rd row seat out of a 2000-Up Suburban to match the front seats and to fit between the rear fenderwells perfectly.
One thing though...I can't get my seatbelts to latch and adjust when I pull the seatbelts out when I am sitting in the seats. The don't latch and hold tight for some reason.
wildmanaaron is offline   Reply With Quote
Old 01-19-2007, 01:11 PM   #17
bodydropped
new model escalade console i got the dvd where the blazer is featured in and he said new model escalade console and i think seats to
bodydropped is offline   Reply With Quote
Old 01-19-2007, 01:47 PM   #18
piecesparts
Thanks guys....
