Old 01-15-2007, 02:55 PM   #1
fnoblitt
fnoblitt's Avatar
advantage of useing 73-87 front member ?
i have a 70 c-10 and was thinking of going to the 73-87 front x member to get the disc brakes and power steering. i see they have rubber control arm bushings instead of the metal ones i have now. does that give it a better ride? are there any other differances that are better than the 70 ?
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 01-15-2007, 03:04 PM   #2
raggedjim
raggedjim's Avatar
Re: advantage of useing 73-87 front member ?
First of all is availability. The 73-87 can be found everywhere.
Second of all, you can buy drop spindles and drop coils for the 73-87 cheaper than the 71-72.
Only downside is you will have to work on the mounting holes a bit.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 01-15-2007, 03:34 PM   #3
fnoblitt
fnoblitt's Avatar
is the ride the same?
Old 01-15-2007, 03:36 PM   #4
jimmydean
jimmydean's Avatar
I doubt there is a huge difference in ride. But the parts availability is key. The pure number of truck made from 67-72 vs. 73-87 (even if you go back to 63) is what makes the swap so popular.
jimmydean is offline   Reply With Quote
Old 01-15-2007, 03:44 PM   #5
fnoblitt
fnoblitt's Avatar
i figured it would be an easy way to get the disc brakes and power steering if nothing else. wolud there be any issues in hooking up the power steering ? or does everything just bolt up ?
Old 01-15-2007, 04:05 PM   #6
jimmydean
jimmydean's Avatar
I pulled the motor and steering box out of a '75 and the box bolted right up. I even mounted the old box in the '75 to make it mobile.
On the '69, I had to notch the bumper bracket to clear the box and I cut a little off the inner fender to clear the hoses, but I don't think you have to do either on a 70.
Old 01-15-2007, 05:12 PM   #7
SCOTI
SCOTI's Avatar
Yes, there is a slight difference in the ride. Both of my swb trucks are lowered using basically the same methods yet the newer 74 rides a little nicer. The 74 has the rubber bushings vs. the rubber-lined steel bushings on the 68.
Availability is the main reason. It's much easier to find replacement parts for 73~87 (& typically cheaper too). You don't have to swap the entire crossmember over if you're rebuilding the front end. Just swap over the a-arms, sway bar, & steering related gear.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2007, 05:48 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Here are the holes I had to modify to put the later model front end in my '70...
LockDoc
Leon
Old 01-16-2007, 05:05 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Good luck, Rg
Newer 'clamshell' engine mounts too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-16-2007, 09:59 AM   #10
Brad
Out of the carpool lane.
Brad's Avatar
I would agree with everything that's been mentioned. Long story short- I hate the old screwstyle control arm shafts and ended up stripping threads on a brand new set. I decided after that to just go with the newer rubber style and haven't looked back!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
