#1 | |
Re: Anyone got a Edelbrock Pro-Flo Multi-Point Electronic Fuel InjectionSystem?
As for the ignition I went with Mallory. They have a dist that plugs right into the harness, it is made for this EFI setup. The coil is also Malory and also for EFI. I will go look at there site and get back to you on with a link....
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() Last edited by Burt4x4; 01-16-2007 at 11:05 AM. |
Here:
http://www.malloryracing.com/Product...Search=6148201 and http://www.malloryracing.com/Product...minselection=4 Hope this helps. Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#3 | |
Thanks, Kade |
My opinion is to get new parts. Mallory was an easy "plug & Play" solution plus they are designed to work with EFI computers/ignitions.
I forget the technical reason but I think it was noise reduction so not to interfear with the computer. But I'm sure the conversion kit works otherwise Edelbrock would not have it with their kit....sup to you just do your homework and make sure the ignition you have won't cause issues with the EFI computer.. .02c Burt
I am getting there slowly.
