WTB cab patch panels
Looking for a
1.pass (maybe driver too) floor panel 2.possibly new inner and outer rockers Both sides. 3. Is there a patch made for the area inside the cab near the corners under the gas tank? I removed my tank today and realized that the PO was using the bottom driver corner of the tank as a patch! BIG HOLE! Will send pics later... thanks.. shipping would be to 17042 Lebanon, PA. Last edited by msgross; 01-01-2007 at 06:10 PM. |
Re: WTB cab patch panels
I have got it all. I am going to be cutting up my 68 cab. If your interested let me know. The cab I am going to cut up for patch panels has an excellent floor somebody started putting in gm rockers. Let me know what you think.
sounds great...
I will get a pic tomorrow of my "problem" areas and see what you can fill in with some pieces. The only holes are in the area under the gas tank on each side.. I can see day light through one and I might be able to fit my foot through the other (and I wear 14's!) I actually removed the pass seat belt by pulling very hard! thanks.. |
Here is what I need... take a look at the pics and see if find other pieces. I already have cab corners and rear floor supports. thanks... I need these items by the end of January...
Weekend Warrior
I know this is a little old. I think you're better off purchasing another cab for the truck. Looks like this one has been molested many times before.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
If there was a good selection around these parts then I would consider...I'm just gonna clean up all the rust areas, patch it, seal it and be done until it's next restoration when all sheet metal needs replaced. No $$ in the budget for a big resto anyway...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Off topic I was wondering if it's a 2wd or a 4wd if it's a 2wd can you post some pics of how the exhaust is routed around the clutch linkage area. And what type of exhaust manifold you are running thank you for your help.
1969 Chevy C-10 350/700r4 |
![]() Join Date: Jan 2001
if you change your mind i may have one a bit better than that. cheap
not perfect but looks better than what you got. ill look it over good , i just picked it up this weekend btw its a 67 cab small window
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 01-17-2007 at 12:35 PM. |
