Old 01-14-2007, 05:47 PM   #1
dbcox
dbcox's Avatar
Any pics of instument panels w/ aftermarket guages
Does anybody have any pics of a instrument panel they may have put aftermarket guages in like auto meter.I like the 2 5/8 size but i think it may look funny if i nount them on the outside may need to do some cutting. Or will the2 1/16 size fit in the stock location and be covered up the panels like the originals.
dbcox is offline   Reply With Quote
Old 01-14-2007, 07:04 PM   #2
BowTieOgre
Re: Any pics of instument panels w/ aftermarket guages
Im wondering the same thing. Lets hope someone has some pics!
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 01-14-2007, 07:28 PM   #3
bigblock73
yeller
bigblock73's Avatar
Mine...
http://www.73-87.com/7387garage/inte...ge_surface.htm
Mikes...
http://www.73-87.com/7387garage/inte...s_recessed.htm
Another...
http://www.73-87.com/7387garage/inte...ashmounted.htm
bigblock73 is offline   Reply With Quote
Old 01-14-2007, 11:00 PM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
Here's mine:
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-15-2007, 11:03 AM   #5
dbcox
dbcox's Avatar
thanks those looked good
Old 01-15-2007, 11:51 AM   #6
Crank
Crank's Avatar
Here are the pictures I've got.
Brandon
Crank is offline   Reply With Quote
Old 01-15-2007, 01:28 PM   #7
hiway
Mad Scientist
Man, I like that last one!
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 01-15-2007, 01:33 PM   #8
hvychve
To The Levy
hvychve's Avatar
not sure what years are interested in , but I will send some of mine. Note the knob just above the speedometer head, they called this a speed minder,I guess they were real rare, I just had to have one. where ever you set the dial if and when the speedo needle hits it, it sounds a warning..just could resist.
hvychve is offline   Reply With Quote
Old 01-17-2007, 03:58 PM   #9
aort
aort's Avatar
Here are a few pics of mine.....
'85 Chevy 383/700R4/205
aort is offline   Reply With Quote
Old 01-17-2007, 11:38 PM   #10
84 400
Sb 400 club
84 400's Avatar
aort: how hard was it to wire those up?? or swb85? Looks like a nice mod to do and i bed it is nice to have that tach.
Also Crank do you have any info on the last ones seats??
Sorry to be off topic
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-17-2007, 11:55 PM   #11
Crank
Crank's Avatar
No sir, have no info on the seats, i think i pulled the picture from cardomain.com or something. They seem to be just aftermarket buckets out of JC Whitney or summit, tho I have no idea truthfully.
Brandon
Old 01-18-2007, 09:39 AM   #12
84slopwaggin
84slopwaggin's Avatar
I enjoy the pics of the autometer gauges, but one day I would like to see what they look like installed from a rear shot. That way I could know how their suppose to look when they are completed. Please whoever does the next gauge installation maybe you could snap a couple of shots of the rear of the installation after it's complete.
84slopwaggin is offline   Reply With Quote
Old 01-18-2007, 10:08 AM   #13
bigblock73
yeller
bigblock73's Avatar
aort posted a rear shot...look at his last picture.
Old 01-18-2007, 11:06 AM   #14
swb85
swb85's Avatar
84 400: The wiring isn't hard at all, but it's very tedious/time consuming. The hardest part was tracing each wire & finding out what it was for.....and after I spent all that time doing that, I realized that had already been done for me here: http://www.73-87.com/7387garage/inte...s_recessed.htm
Old 01-18-2007, 07:33 PM   #15
84 400
Sb 400 club
84 400's Avatar
wow thanks for the link!!! I used to think the autometers took away from the look butthe function aspect must be nice. Thanks again swb85 for the link
1985 C10 LWB Sold
Old 01-18-2007, 10:48 PM   #16
aort
aort's Avatar
The wiring is pretty simple. The wires are all ran for the stock gauges. All you have to do is get an ohm meter to test which wires are which if you don't have access to a wiring diagram. Then you just hook up the wires to the sending units from the plug outside the firewall to corresponding wires in the dash. There should also be wires in the stock harness for the lights as well. If you have anymore questions feel free to ask. Alex
Old 01-19-2007, 12:08 AM   #17
84slopwaggin
I was talking about the other side of the gauges. The side facing the fire wall when the dash is closed up. I'd like to know what it takes to massage all the gauges into place. 84 400 I think this theme would go great in your truck with the 400sbc. If I could I would install them in every truck I own.
Old 01-19-2007, 12:16 AM   #18
bigblock73
yeller
bigblock73's Avatar
Oh, I got ya...sorry about that.
When I installed mine into the dash, I had to install the two left ones seperately, with them installed in the bezel prior, the bezel could not be installed in the truck...there was interference. It was not a big deal, just a lot of reaching and ackward arm positions.
Old 01-19-2007, 12:43 AM   #19
HAVA79
Master Blaster
HAVA79's Avatar
Bigblock, your painless link in your attachment does not work. Is this a harness attachment that plugs into your factory instrument cluster plug and then onto your autometer guages???? I have installed a painless 18 circuit kit in my blazer and am very disappointed with the factory guages. I would like to find something that I could just plug into the cluster plug and have labeled seperate wires to the autometer guages(maybe wishfull thinking).........jesse
HAVA79 is offline   Reply With Quote
Old 01-19-2007, 02:01 AM   #20
84 400
Sb 400 club
84 400's Avatar
Thanks for the kind words man. I think they would look good to. I used to hate them but the stockers just are not doing it for me. Also i am not sure if this is what you want but i pulled this off the link
photo by : Mike Ervin
1985 C10 LWB Sold
Old 01-19-2007, 07:41 AM   #21
bigblock73
yeller
bigblock73's Avatar
The Painless kit comes pre-assembled..you just have to follow their diagram to hook up your gauges properly. It is pretty easy, and I even hate electrical work. The only thing you have to do is put connectors on your wiring kit and gauges...I used male/female insulated connectors...that way I can easily remove one, two, or all of the gauges if I choose to without having to remove the entire wiring harness. I also have the Painless 18 curcuit 73-87 wiring harness.
Thanks for the heads up on the link, I will fix that this evening.
Old 01-19-2007, 08:47 AM   #22
KMK454
KMK454's Avatar
Some very nice setups! Love those autometer gauges. Must... resist... temptation... to mod...
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 01-19-2007, 09:23 AM   #23
HAVA79
Master Blaster
HAVA79's Avatar
bigblock, did you remove the original style cluster plug all together?
Old 01-19-2007, 09:45 AM   #24
bigblock73
yeller
bigblock73's Avatar
IIRC, there was no plug...but if there was, then yes, I cut it off and wired each gauge individually, matching the truck harness to the gauge harness.
Old 01-19-2007, 10:11 AM   #25
HAVA79
Master Blaster
HAVA79's Avatar
thanks..........jesse
