Old 01-17-2007, 03:38 PM   #1
ClassicRedneck05
ClassicRedneck05's Avatar
Brake Lines as Transmission Lines
had a friend tell me that i could use brake lines from my local auto parts store to make my own transmission lines said they were the same can anyone confirm this?
ClassicRedneck05 is offline   Reply With Quote
Old 01-17-2007, 03:57 PM   #2
neonlarry
neonlarry's Avatar
Re: Brake Lines as Transmission Lines
Brake lines are usually a lot smaller in diameter.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-17-2007, 04:02 PM   #3
ClassicRedneck05
thats what i thought
Old 01-17-2007, 04:07 PM   #4
454_72_4X4
454_72_4X4's Avatar
I assume your friend was talking about the steel tubing that parts stores sell in different lengths and sizes.
If that's what he was refering to then, yes you can use it for transmission line.
Most auto trans use 5/16 lines.
I use it alot for trans lines, brake line, and fuel lines.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-17-2007, 04:11 PM   #5
ClassicRedneck05
any idea on how much it sells for? i need to replace my tranny lines and im lookin to go the cheapest way i priced tranny lies and they were expensive
Old 01-17-2007, 04:23 PM   #6
kevenj
5/16" steel brake lines are what you need. same thread as the tranny cooler fitting on the transmission or radiator.
you can get them at Napa, here are part numbrs:
20" long 813-1231
30" long 813-1232
40" long 813-1233
51" long 813-1234
60" long 813-1235
If you need a coupler to put 2 lines together the part number is 302x5
You can bend them by hand unless it's a really tight bend, if so you can get a hand held bender at Napa also, part number 775-9001 (taiwan made) or #2517 (US made) - - works best if you clamp the handle of the bender in a vise even though they are "hand held".
kevenj is offline   Reply With Quote
