Old 01-17-2007, 06:24 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: Clean up the motor and compartment
How much was that braided fuel line? I def. want to go with something other than rubber after all of, well, you know
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 01-17-2007, 06:33 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
When I was looking at the 1406, summit had a hard line for it that ran most or all of the way between the pump and the carb. It was summit branded, so it was pretty inexpensive as far as those things go.
Back on topic, I would keep the vent hoses from the valve cover for the reasons mentioned. You could go with vents instead, but they might blow oil on the engine. That would not be an improvement.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-17-2007, 09:54 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I put this motor in my 84 GMC with the Thunder AVS carb and a solid fuel line from Edelbrock. I have the Edelbrock fuel pump on the side of the motor feeding up to the billet fuel filter that is on the Edelbrock solid feed line. The fuel line is summit's braided line with AN fittings on it for finish. I decided a while back that I was done with fuel line hose clamps. From now on I will use finished fittings.
Old 01-17-2007, 11:06 PM   #4
84 400
Sb 400 club
84 400's Avatar
Thanks for al the pointer guys. The cap on the passengers side with thte hose goes to the front of the carb but were it meeds the gromet on the valve cover it leaks alittle oil. on the drivers side i have a filter going in the valve cover. you can see it in this pic. Also Cliffsta the kit is avalible through summit carries ther own brand and also sells edlebrock version. the summit one is on page 27 of ther catilog. It is called fule pump to carb hose kit. It comes with braided line and AN fittings. part # SUM 631522 or SUM 63150.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
