Aluminum slot wheels rule...
It's driving me nuts!!
Alright, I've had it. Ever since I've bought my truck, there has been a really incredibly annoying squeaking coming from under my dashboard somewhere. I don't know where, but it's somwhere. I've peeked up in there a few times, but I can't see anything that would or could make a sqeauking noise. It's a rubber squeak, I can tell that. It isn't mice because they all moved out of my truck after I got it. Can you guys give me some suggestions as to what this could be? I know it could be damn near anything, but I've looked, and I can't seem to pin it down. Any and all help (relavent or not
![]() Jake |
Re: It's driving me nuts!!
could it possibly be one of the vent hoses squeaking on the plastic they're connected to i would check em but be careful cause if you aren't then you'll have a real mess on your hands
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
im having the exact same problem and its driving me nuts to, i second the hose deal but i havnt checked mine yet so if you find out what solves it for you please post what it was and also goodluck with finding it
-steven ![]()
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME Last edited by GREASEMONKEY72; 01-16-2007 at 10:37 PM. |
Currently Blazerless
I had an annoying squuek in my truck coming from under the dash, finally figured out it was the speedometer cable. Lubricated it with graphite and it was gone.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Tool Addiction=Money Shortage
My blazer had this problem I was sure it was coming from the inside. I searched off and on for weeks. It turned out to be the hood rubbing on a rubber bumper on the cowl. I didnt find it till i drove with the hood partially open and the squeak stopped. I put a shot of silicone lube on the bumper and the squeak has been gone for a couple years.
It would be worth your time to check out. |
My clutch squeaks like crazy. I have tried a million different lubes, oils, sprays, and nothing has worked. I'm just installing a loud stereo to compensate
Something under my dash squeaks also. sounds like its coming from the passenger side. more like a chirp though I think but none the less its very annoying.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
I am a Referee of life.
Check the bolts and bushings on the windsheild wiper motor.They could be loose or worn and allow the rubber to squeak as it shakes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#9 | |
#10 | |
if its on the passenger side, id check the blower motor, mine make that kinda noise until it gets warmer up then goes away. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
i just reach over a stick a rag in her mouth.. ran quite ever since
