I'm trying to install a new antenna, but can't figure out how to get the wire to the stereo. It had none when I bought it, but the hole is there. It just opens up to the cowl area where the heater air draws from.
It's an 69 bare bones Air Force truck, but I assume it came with an antenna originally.
1969 C10 Stepside, 350ci, 700R4 |
Out of the carpool lane.
Re: Antenna wire routing?
There should be a hole just underneath the cowl. You'll need to take that off and you'll see it on the passenger side.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Resident Curmudgeon
![]() Join Date: Dec 1999
The stock hole for the antenna lead is shown in this pic. It is the hole below the windshield opening by the front cab pillar. It is hidden by the cowl when installed.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 01-15-2007 at 12:31 PM. |
Thanks for the pic...
I pulled the glovebox, and see a flat spot in that location that is not drilled. The rpo list has a "radio delete" option, so that explains that. I found some type of hidden antenna glued to the back of the cardboard glovebox. So I gues I can put the real antenna in there or just fill the hole in the cowl.
