Old 01-18-2007, 01:32 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Re: Rear seat swap
Originally Posted by Jtrux View Post
You can go ahead and give me your old seat then, just make sure to recover it for me first.
I knew that was coming...I will trade it to you for a good top (not your crappy sunroof one).
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-18-2007, 04:04 PM   #2
BUDDY
Global warming is a myth
BUDDY's Avatar
Thumbs up Re: Rear seat swap
I want to do the split rear seat as well. Couple of reasons, they have seatbelts built in, they make the cargo area very flexible, & it's easier to remove them when they weigh half as much. You can get the brackets for these on EBAY as well, but they're a little more money.
LAter,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 01-18-2007, 05:42 PM   #3
70rs/ss
70rs/ss's Avatar
Re: Rear seat swap
I have two seats, but no brackets, one from a 96 burb and an o5 Yukon (namely the one I rolled!) I intend to put one or the other in the K5, When I get round to it I'll probably put the original 72 on the bay!!
70rs/ss is offline   Reply With Quote
Old 01-18-2007, 08:05 PM   #4
tdkosta
tdkosta's Avatar
Re: Rear seat swap
I have a set of 3rd row seats from my '01 GMC, I am also looking to install brackets in my '71 blazer for the same reasons listed above. I did some measuring, and it looks like the seats should fit in fine between the wheel wells. I have a 60/40 split bench from a 96 extended cab pick up that I plan on putting in the front. Now the question is do I pick up a second set of third row seats from ebay and have the seats from the '96 and the new third row covered to match, or do I have the seats from the '96 covered to match the third row seats I currently have in my '01 GMC and just use them in both vehicles as needed? Doesn't it all come down to money?
tdkosta is offline   Reply With Quote
Old 01-19-2007, 02:03 PM   #5
70rs/ss
70rs/ss's Avatar
Re: Rear seat swap
Originally Posted by BUDDY View Post
I want split seat, Couple of reasons, they have seatbelts built in.
LAter,
Buddy
Buddy,
The one out of my 05 Yukon has the belts built in and it is a one pice. I understand your point about being able to pull one or both, but just wanted to point out that all new seats have the belts built in (except the second row, as they are mounted to the truck to allow flipping up of the middle row to enter back row!
Old 01-22-2007, 10:57 AM   #6
BUDDY
BUDDY's Avatar
Wink Re: Rear seat swap
Originally Posted by 70rs/ss View Post
Buddy,
Good to know!!
I had a 60/40 bench in my blazer when I bought it & it didn't work very well. The passenger side bracket for the 60 seat was uneven, (the front of the bracket was higher than the rear), which made the seat not attach to the floor very well in that area.
You could probably figure out something to make it work. But it will definitely take some work. I just wanted to pass on my experience with those type seats in these type trucks.
Later,
Buddy
Henderson, NV
1990 K5 with 37's
Old 01-18-2007, 11:18 PM   #7
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Rear seat swap
Sure...the way I see it if every time I come over I talk you into pulling just one more thing off your Blazer, i'll definitely be driving mine before you. So far you don't have a gas tank in it and your radiator is out (it's not my fault your radiator is out but i'll take credit anyways).
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
