![]() Join Date: May 2002
Squeal
In the last 2-3 months, the blue beast has contracted
squealing brake syndrome. After applying the brakes about 10 or 12 times they start to squeal at the end of the braking process. I have no problem stopping and they are not pulling left or right. Its really not a problem...just sort of annoying. I pulled the front drums and there is plenty of material on the shoes. When I pull back into the driveway from a trip across town I touch the front drums and they are warm but not hot and they are both about the same temperature. I pulled the rear drums and they also have plenty of material on them. So...is this squealing just a consequence of having drums as opposed to discs? Also...what generally is the difference, if any, between a HEI distributor and a breakerless distributor...is there an ID number on the distributor that tells exactly what type it is. (It has the coil in the cap). Thanks! Jim M. The weatherman ![]() __________________________________________________________ 1969 C10 Pickup 350CID/th350 3.73 rearend |
